Hello! I was wondering if anyone knew these wheel arches and where to get them?
Posted 20 March 2017 - 08:57 AM
Posted 20 March 2017 - 04:40 PM
Posted 20 March 2017 - 05:13 PM
The are, in fact, wheel arch EXTENSIONS. The wheel arches are part of the metal wings and side panels.
Posted 20 March 2017 - 07:38 PM
Posted 20 March 2017 - 08:11 PM
Cars like MK.1 Ford Escorts and Porsche 911's had arch extensions which were welded on if wider wheels were needed for racing. They actually added strength to the body and were strong when you hit them against a wall or another car.
I have never liked the arch extensions on Minis ever since I fitted my first set in about 1969, then I accidentally hit one with a spare wheel and it cracked. I now try to avoid fitting them if possible as they are fragile and promote rust in the steel wings and body. You only really need them if wheels wider than 5" are fitted or is the datum offset is not as standard.
Posted 20 March 2017 - 10:29 PM
My mini GT 1275 came with wheel arches but now I want to change/upgrade them, and this (the image i attached) is the arch extenders I want to go for.
Thanks for the comments (:
Posted 21 March 2017 - 09:37 AM
Posted 22 March 2017 - 07:45 AM
Jon - Im looking into but can't find anything yet. Might of been a one off/hand made sort of thing...
Posted 22 March 2017 - 01:13 PM
Posted 22 March 2017 - 02:49 PM
Those are very wide arches, you need wide wheels for them to look OK....
The arches in the pics by OP IIRC are something like Gp5...?
Posted 22 March 2017 - 02:51 PM
Posted 22 March 2017 - 02:52 PM
the arches on the white GT above look like group 5(or group 5 wide) or group 7 arches.. names vary a bit depending on supplier
Posted 22 March 2017 - 03:02 PM
