Jdimini Mg Midget Restoration @ Mill Road Garage Isle Of Wight
313 replies to this topic
#61 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 May 2017 - 04:27 PM
You must be pleased how good it looks after the blasting! Hopefully an easy job to do the rest of the welding.
Very pleased, did wonder if it would resemble a tea bag after the blasting and Ben does a brilliant job fabricating and welding
Thanks Darren.
sorry for the lack of updates these past two days, been off with Flu.
I went in this morning to catch up but the compressor is down. Someone in the neighboring building has disturbed the wiring when upgrading their own.  :goaway:
It's being sorted over the weekend though...
Ben
#62 JDImini
JDImini
  • 679 posts
Posted 22 May 2017 - 09:13 PM
Hi Ben
Hope you feel better soon
Darren
#63 JDImini
JDImini
  • 679 posts
Posted 23 May 2017 - 09:56 PM
goodies on the way from Frontline Developments  :-)
#64 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 May 2017 - 06:18 PM
I started work on the left hand sill today.
I thought this was the better side but infact, it turned out to be the worst...
Never mind, time to start removing the old one.
I started off by removing the front section so that i could get a better look at a suspect section of inner sill
And this is the section that i was half expecting to be much worse than it turned out to be
The back half is not to bad but the closing panel on the end will need replacing
There is also a hole in the bottom of the quarter panel
The front lower half of the inner sill will need similar attention to the other side
With the rest of the sill removed, i could get a better overall look
It really amazes me how things can be behind a perfectly excellent looking sill
Now it was time to start cleaning back the rust to see what actually needed repairing.
Off with the rear closer
Which is not to bad behind
The front closer was also removed and there was some rust behind so ill need to repair this side the same as the other
Holes.....
This is the first hole i found after a clean up
I think ill remove a section of the inner sill in front of the hole and replace the section behind from this side. It's quite a squeeze in the footwells of this car
Ill need to repair this part too
It had torn away from the sill.
On with the repairs, I thought i would start off with the back end this time
I repaired the hole int he quarter panel
And then made up the new rear closing panel
And then trial fitted it in place
I have also cleaned up to clean bare metal the vast majority of the inner sill but didn't get a picture.
Tomorrow, ill repair the inner sill section at the front and make up the closing panel for there too and then i can prep and fit the new sill.
Ben
#65 JDImini
JDImini
  • 679 posts
Posted 24 May 2017 - 09:15 PM
yet more great work!
#66 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 May 2017 - 10:05 PM
Thanks Darren. :-)
#67 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 May 2017 - 08:05 PM
More progress with the inner sill repairs today.
I repaired the hole above the inner sill at the front
And today i mourn the loss of a dear and old friend.. We have been together 12 years  :cry:
Yeah, that's broken
I Have ordered a replacement but have to wait for delivery so a cheap one bought locally would have to do whilst i wait.
Don't buy a cheap one of these like I did today, it lasted barely 30 seconds before it packed up.  >:(
Ok, on to the lower inner sill repairs.
I cut the rotten holed piece out
And then did the same with the front piece
And then de-rusted in there and zinc sprayed it all up
I needed to make the front piece first
Which went in just fine
Followed by the piece of sill
All welded and ground up
I still need to make the front closer but for now, i zinc sprayed the entire inner sill
Before trial fitting the new outer sill
Something is wrong though as it won't move up high enough.
I shall investigate that tomorrow.
Ben
#68 carthorse
carthorse
  • 257 posts
Posted 25 May 2017 - 09:32 PM
The el'cheapo 90' die grinder I bought off fleabay a few months ago refused to run at all despite multiple attempts at taking it to bits and fettling it's nasty badly cast insides
The Clarke one I replaced it with from Machine Mart works well without being daft Snap On / Blue Point money
#69 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 May 2017 - 09:59 PM
The one i got today just shook itself to bits in moments. It runs at too higher revs for the cheap components to cope with.
The one that broke has worked perfectly for the past 12 years and is by Universal tools. I believe it was around £100
I'm replacing it with the latest version of the same model which is now £120.
Money well spent on a tool that is used everyday and i know is good quality.
But i at least expected the cheap one to last a week until the replacement arrived....
#70 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 26 May 2017 - 02:59 PM
Quality work on this as usual! Ben, got to agree on the cheapo die grinder, i
bought one of those of evil bay and it lasted 2mins , plus was got in touch with
Tool Zone and they re funded costs and told me to bin it,
#71 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 May 2017 - 07:01 PM
Back on with the sill fitting today.
I had a play with the reluctant-to-fit sill first of all and have managed to get it to fit nicely.
With the sill back off, I marked out and drilled the trim and badge holes
Then prepped it for welding and sprayed up the inside
Next, I refitted the sill and tried on the wing to check for fit
Before welding it top and bottom
I sprayed up the rear closing panel that i made the other day
Which goes here.
And then welded it into place
And then I made up a new front closer
And fitted that too
And that concludes the sill fitting :-)
So with the structural welding complete, the bracing could come out
And now it's time to re-skin the doors.
My ex glamorous assistant removed them from the car when he was still here and i though he had stripped them out.
He hadn't so that needed doing before I could remove the old skin.
Here is the damage
Just like a Mini  :rolleyes:
Once I stripped the gubbins out of the door, i cut the skin off
Which showed the extent of the frame damage
So ill make up a complete new bottom section which will sort that.
And that was all i had time for today.
Ben
#72 Carlos W
Carlos W
  • 10,114 posts
Posted 26 May 2017 - 07:54 PM
Excellent work as always Ben
#73 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 27 May 2017 - 05:45 PM
Top work as always Ben, really enjoying this project. The shell was in fantastic condition to start with considering its age and the lack of rust proofing from the factory.
#74 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 27 May 2017 - 06:47 PM
What keeps the water out of here?
#75 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 May 2017 - 07:09 PM
A rubber bung.
Ben
