Jdimini Mg Midget Restoration @ Mill Road Garage Isle Of Wight
313 replies to this topic
#46 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 May 2017 - 05:35 PM
The Midget is now back from the blasters.
I have high praise for Martin at MJG grits in Godshill Isle of Wight. We haven't used them before and i'm very impressed with the quality and attention to detail.
Here are some pictures from yesterday when it was at his place.
5xycpIE.jpg?1
Ykr9Jnc.jpg?1
And here are some more pictures i took when it arrived back to the garage this afternoon.
As you can see, the shell is in fantastic condition. There are a few areas of shallow pitting namely on the battery tray and the tops of the inner front arches.
There are holes on the bottoms of the quarter panels both sides which we knew about and some heavier pitting across the back where the hood attaches.
The underside is perfect. It has never been welded anywhere and is totally original.
Unbelievable considering its a 46 year old car!
Ben
#47 MrBounce
MrBounce
  • 2,660 posts
Posted 11 May 2017 - 09:04 PM
That looks REALLY good considering how rotten these usually are. Fantastic base to start from!  :thumbsup:
#48 JDImini
JDImini
  • 679 posts
Posted 12 May 2017 - 08:19 PM
Very Happy! :D
#49 JDImini
JDImini
  • 679 posts
Posted 12 May 2017 - 09:04 PM
Hi Ben,
the toys are as per the list I sent a a couple of weeks ago I'll be paying early next week so will be sent down then. I'll let you have dates when I know
 cheers Darren
#50 JDImini
JDImini
  • 679 posts
Posted 12 May 2017 - 09:21 PM
Hi Ben please pass on my thanks to Martin, looks like he's done a great job, although the selfie was a bit scary :ohno:
#51 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2017 - 09:06 AM
I will do Darren.
I need to go over to see him next week with the front panel and radiator surround tinwear. I'm looking forward to having a chat with him.
I'm glad we found him, he really seems to be into what he is doing.
Ben
#52 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 May 2017 - 05:31 PM
Hi all.
Today, I have made a start with the panel work on the Midget.
I started off by raising it up to a working height
And then added some bracing
I decided to start off by removing the o/s outer sill. They look pretty good but there was no real access to see inside so it's been decided to take no chances and fit a pair of new sills
I can't remove it in one piece because of the construction of the shell so it was important to keep the face of the sill as neat and intact as possible so that i can transfer over the badge and trim holes accurately onto the new sill
My concerns about the condition behind were due to the pitting seen here.
And also a couple of small holes on the underside of the sill.
So with the sill removed, I could see how bad the rust was beneath.
Not too bad considering. There is some pitting and surface rust to deal with and a couple of sections to replace later.
After removing the remains of the sill from the base of the quarter panel and a post, there was some more minor rust to deal with
The next thing to do was begin cleaning up the inner sill.
Here is one half done
That half cleaned up perfectly so no attention is required.
Here is the remaining half cleaned.
There is some minor pitting on the outside but the inside is perfect so due to the thickness of the steel, it will only require treating and painting with the exception of a small section right at the front.
This is the sill closing panel at the front
It's pretty thin and crusty so will need replacing.
beneath it was quite a lot of rust and it had holed in a few places
Nothing for it but to cut it out and replace this section.
here it is with the rough bit removed
And after cleaning it up to bright steel, i set about fabricating a new section.
First it was marked out on steel
Then cut out and clamped into place
Once i was happy with the fit, i tacked it into place
Then seam welded it
And then after a clean up, that section is complete bar a couple of spot welds which i shall do tomorrow
The pencil line shows the position of the flange behind so i know where to put the spot welds.
The other section that needed replacing was at the front of the inner sill
The pitting was too deep here and it had started to go through.
I cut it out and then used it as a template for a new piece as before with the other section
And then clamped it in ready for welding
And that was all i had time for today.
Tomorrow, i shall complete these repairs and get the new outer sill fitted.
Then onto the other side.
Thanks for looking.
Ben
#53 JDImini
JDImini
  • 679 posts
Posted 16 May 2017 - 09:48 PM
Hi Ben,
brilliant work, as always!
very pleased that the sills are being replaced as although they looked very good they were hiding some nasties
thanks
Darren
#54 JDImini
JDImini
  • 679 posts
Posted 16 May 2017 - 09:53 PM
goodies for the midget to improve handling, stopping and safety have been ordered from frontline developments. I'll let you know when I get a shipping date
#55 Simont
Simont
  • 198 posts
  • Local Club: Thames Valley Mini Club
Posted 17 May 2017 - 09:00 AM
Would you mind if i asked how much you paid for the tub blasting?
thinking about getting my dads rubber bumper midget done,
#56 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 May 2017 - 05:45 PM
I think we paid around the £400 mark for this one.
Everything will be different though I expect. It all comes down to how long it will take. e.g, lots of layers of underseal or lashings of filler will take longer to remove and cost more to have done.
Hope that helps
Ben
Edited by Ben_O, 17 May 2017 - 05:46 PM.
#57 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 May 2017 - 06:18 PM
Back to the sill replacement today.
I started off by finishing off the inner sill repair from yesterday.
Here it is tacked in ready
And then welded fully and linished back
Then all i had to do to finish these repairs was to spot weld the flanges back
After a liberal coating of zinc, I was ready to start prepping the new sill
The old sill had several holes drilled into it for the purpose of mounting the 'MIDGET' badges and the chrome finishing trim along the length of the sill so i needed to drill these into the new sill as they come undrilled.
Here is the new sill after I stripped the edges back to bare metal ready for welding
And then i clamped the first section of the old sill into place to use as a guide for the holes
And here they are drilled
Then i did the same with the other half of the sill for the remaining trim clip holes
So now it's ready to fit to the car
The large area of bare metal forward of the jacking point hole is where i had to file some minor ripples in the panel. Best to do it now...
And then I Zinc primed the inside of the sill
Before offering it up to the car.
It pretty much fell into place with barely any jiggery pokery required to get it nicely lined up.
I placed the wing on also to just check that the gaps were acceptable
Now the welding can begin.
Here is the bottom lip spot welded to the floor inner sill
And then the top of the step
Next was the top front lip to inner wing
And then the back edge closer, B post and A post respectively
Those were taken after i finished as i forgot to take photos during  >_<
With the welding complete, I turned my attention to the front sill closing panel which as i showed before, was in quite a state
So a new one was needed and they are a bargain at £15 each. I didn't order any when i placed my panel order so decided to just make one up myself.
Here is where it goes
I used the old one to mark out a template onto sheet steel
And then after some cutting, bending, folding and welding, I had my closing panel
Which fits nicely In place
And here it is after spot welding it and priming
So with the fitting complete, I added some slugs of mig weld here and there for good measure and primed it up temporarily.
So that's one side complete, Just need to get the other done now.
I'm expecting exactly the same story there so hopefully it's not worse.
Thanks for looking
Ben
#58 JDImini
JDImini
  • 679 posts
Posted 17 May 2017 - 09:09 PM
Hi Ben, looking brilliant
Darren
#59 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 18 May 2017 - 09:40 PM
You must be pleased how good it looks after the blasting! Hopefully an easy job to do the rest of the welding.
#60 JDImini
JDImini
  • 679 posts
Posted 20 May 2017 - 02:30 PM
Very pleased, did wonder if it would resemble a tea bag after the blasting and Ben does a brilliant job fabricating and welding
