Update time.
I finished polishing the front deck and fitted the wiper wheelboxes, washer jets, padded rail and tourneo press studs as well as the fresh air de-mister vents
I then fitted a new windscreen frame to body seal to the windscreen frame and attempted to fit the screen to the car.
If you think fitting a Mini screen can be tricky..... This is in another league.
The main issue is the new seal. Its so hard and thick that when fastening the screen down, the rubber won't compress enough and the stress keeps putting a dip in the scuttle.
I had the screen on and off about 3 or 4 times trying to get it to fit nicely and in the end gave up.
I'm on my own this week and it's really a 2 man job so that will have to be done next week.
Well here is the latest parts haul
The main parts I was waiting for are the wishbones and king pins so that I can assemble and fit the front suspension and hubs.
As you may remember from earlier in the thread, this car is having uprated suspension and brakes fitted which comes in kit form so required quite a bit of head scratching to put together nicely.
The finish of some of the components wasn't the best. Mainly some threaded parts like the shock mounts were not drilled and tapped deep enough fo the bolts so needed sorting.
Also, the new top arms foul the brake pipes when routed in their original position so they needed to be relocated which meant making up another set of new brake pipes.
Anyway, progress was made and I soon had one side on
You can see the brake pipe in it's original position would be crushed by the top arm at full droop so I drilled through the inner wing and moved them out of the way
And then with the hubs and brakes on, one side is complete
And with the shock
I still need to paint the hub and steering arm. I was reluctant to do that first as I knew I would need to make some adjustments and slight mods to them for everything to fit so that will be done after everything is fitted and the car is rolling.
And here is the other side minus the shock. I still need to drill and tap a deeper thread into the bottom arm to accept the shock absorber bolt before it can go on
And here is the re-located brake pipe for this side
I'm not sure until I get the wheels on and the car on the ground but I may need to space the top trunnions slightly which will mean removing the springs again.
I have made a special tool to make that easier so won't be the end of the world if it has to happen.
Once I am happy with the front suspension, Ill get the steering rack fitted and the ARB. I think that the steering arm may need spacing back more so that the track rod ends don't foul the brake discs but ill cross that bridge when I come to it.
Ben
