Jdimini Mg Midget Restoration @ Mill Road Garage Isle Of Wight
313 replies to this topic
#181 JDImini
JDImini
  • 683 posts
Posted 18 August 2017 - 02:22 PM
Hi Ben,
do you think the car will be ready for me to take to Goodwood Revival which is  8, 9 & 10 September?
Darren
#182 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 August 2017 - 02:27 PM
Hi Ben,
Darren
I'm on it and ill do my very best!
#183 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 August 2017 - 05:15 PM
Now the shell is painted, It's time to focus on getting it rolling.
So first up is the rear axle.
I stripped off the springs, brakes and other bits ready for a de-rust and repaint
And nothing wins against the might of the twisted wire brush in a grinder
I then spent some time cleaning up the spring hangers, mounting plates and U bolts before de-greasing and applying black primer
Once that had flashed off, on went the gloss black
I then rolled the engine outside and gave it a through scrub ready to dismantle and prep for paint on monday
Ben
#184 JDImini
JDImini
  • 683 posts
Posted 18 August 2017 - 05:45 PM
Hi Ben,
Darren
Thank you!
#185 JDImini
JDImini
  • 683 posts
Posted 18 August 2017 - 05:46 PM
That's one pink mini in the background
#186 JDImini
JDImini
  • 683 posts
Posted 18 August 2017 - 05:52 PM
"And nothing wins against the might of the twisted wire brush in a grinder"
You certainly don't want to get a finger in the way
#187 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 August 2017 - 06:17 PM
Pink and rusty  ;D
#188 JDImini
JDImini
  • 683 posts
Posted 20 August 2017 - 10:30 PM
Pink and rusty  ;D
Not for long if you get a chance
#189 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 August 2017 - 05:29 PM
Pink and rusty  ;D
Nothing will be happening this year I wouldn't have thought.
On with today's update.I prepped and painted the rear axle, leaf springs and brake drums
And then once dry, I laid everything out ready for re-assembly
I went for gloss black on everything except the brake drums which I did Satin to contrast against the gloss although it doesn't really show in the photos.
I also rolled the shell out of the booth ready for  a good clean and sweep so I can get the next lot of stuff in to paint
This afternoon, I removed the gearbox and ancillaries from the engine so I could prep that for paint
That is no de-rusted, de-greased and in the booth ready for primer and paint. I'm going to do the block and head satin black and then the rocker cover, timing chain cover and sump gloss black. I think the starter motor ought to be satin black too.
I failed to get a photo of the prepped engine so ill do that in the morning before I paint it.
Ben
#190 Carlos W
Carlos W
  • 10,115 posts
Posted 22 August 2017 - 06:53 AM
Wow.
There's a lot of little bits to prep up and paint.
Remember not to use the twisted knot wheel for too long
#191 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 August 2017 - 10:14 AM
Wow.
There is still lots more bits to do.
Engine is now painted though so it can be refitted to the shell. :-)
And yes, I know about the problems with using the wire wheel for too long....
Did it yesterday. oops
#192 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 22 August 2017 - 10:49 AM
Fantastic work Ben, I'm really enjoying following your rebuild threads.
I've had a quick Google but I can't find anything about using twisted knot wire wheel too long, can you explain?
I do fear I may have just asked where I can find chicken lips though!
#193 Carlos W
Carlos W
  • 10,115 posts
Posted 22 August 2017 - 11:39 AM
I've found they go out of balance quite quickly and vibrate like anything.
#194 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 August 2017 - 05:14 PM
As Carlos says, they are quite big and not very well balanced so are very tiring on the arms when using for longer periods of time.
Also beware the flying strands!
#195 Haygate
Haygate
  • 115 posts
Posted 22 August 2017 - 05:21 PM
Yep I'm with death row, great thread and makes me always wonder how much for a rebuild of this depth. Keep the builds coming.
    Bing (2)
