Jdimini Mg Midget Restoration @ Mill Road Garage Isle Of Wight
313 replies to this topic
#166 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 10 August 2017 - 07:56 PM
Ben, why do you guys stone chip coat the entire underside of the car? Do you have a lot of loose gravel roads over there? I thought that stuff was for areas that were susceptible to rocks thrown up from the tires, like inner fenders, sills and such.....
Over here they do a proper epoxy seal coat and seam sealer then top coat....seems to hold up just fine. Just curious, seems like all you all are really into that stone chip stuff.
#167 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 August 2017 - 08:02 PM
Partly as a belts and braces approach (they use a lot of salt on the roads here) so the better the protection, the better the underside will hopefully last
But also partly I was copying what was there before I started the work
#168 JDImini
JDImini
  • 683 posts
Posted 10 August 2017 - 09:24 PM
You're doing a great job Ben
Love the look of being body colour underneath not black under seal
#169 joshw
joshw
  • 154 posts
Posted 11 August 2017 - 08:26 PM
Stunning work and attention to detail, I've always wanted a midget with Ashley James hardtop.
#170 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 August 2017 - 08:28 PM
Yesterday, I got the inside of the other wing de-rusted.
No pictures of that because it was exactly the same as the other one.
Whilst I was sorting the other wing, I got the first one into primer
And then once the primer had cured, I swapped them round, primed the second wing and started flatting the primer on the first
And the first finished wing ready for top coat
The second wing is nearly flatted as well now. I have done them entirely by hand due to all of the curves and it is well worth the effort.
Well that's the wings sorted now. They were a lot of work but are now in fine shape :-)
Ben
#171 Magneto
Magneto
  • 891 posts
Posted 12 August 2017 - 10:50 PM
Ben, when you top coat the body, do you put all the pieces back together and paint as one, or do you paint the doors, bonnet and wings separately?
#172 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 August 2017 - 10:49 AM
The doors, bonnet and bootlid will be painted separately.
The wings are seam sealed to the front panel on the front joins so I have two options.
1. I paint the engine compartment and then bolt on the wings and front panel, seam seal the joins and then paint them on the car
2. I paint the wings and front panel off the car, build up the engine compartment/fit the engine etc and then bolt them on painted, seal the joins and the paint them in after.
I'm leaning more towards option 2 as several of the engine bay components will need to be fitted before the wings because of access...
Ben
#173 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 August 2017 - 06:26 PM
I have now painted the inside of the shell.
First, the outside needed to be masked up
And then on with the colour
Ben
#174 timmy850
timmy850
  • 3,605 posts
  • Local Club: MITG
Posted 15 August 2017 - 11:21 PM
Thats a lovely colour!
#175 JDImini
JDImini
  • 683 posts
Posted 16 August 2017 - 10:51 AM
Hi Ben,
it's looking great!
#176 JDImini
JDImini
  • 683 posts
Posted 16 August 2017 - 10:55 AM
I'm pleased I stuck with the original colour
Edited by JDImini, 17 August 2017 - 11:00 PM.
#177 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 August 2017 - 02:41 PM
Ill leave that to harden up fully and flat and polish it on Tuesday.
The the rebuild can begin.
I have decided to leave painting the wings and other panels until I'm ready to fit them, that way, there is no chance of them getting damaged in storage
Ben
#178 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 17 August 2017 - 07:09 PM
Hi Ben,
Is that just the colour coat or is it clear coated too? How many coats? It looks fantastic!
#179 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 August 2017 - 07:13 PM
Hi Ben,
I painted this with solid direct gloss so no clear coat
It only really needs 2 coats but I added a third to give me lots to cut back and machine polish up for maximum depth.
Ben
#180 JDImini
JDImini
  • 683 posts
Posted 17 August 2017 - 11:07 PM
Bloody marvellous!
