Jdimini Mg Midget Restoration @ Mill Road Garage Isle Of Wight
313 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 06 March 2017 - 08:40 PM
Hi All.
The next restoration is underway here and this time it's an MG Midget.
Its a very good example with only fairly minor cosmetic issues that let it down.
It is going to have a full body respray, new Door skins, New sills and a new bonnet.
I shall also be refreshing the suspension as its a bit soggy at the moment.
we have had the car in storage here for a while now so the photos below are taken over that time.
The bonnet has been repaired at some stage and is starting to crack so a new bonnet is going to be in order
The doors are starting to break out along the bottoms so new skins and frame repairs will be carried out
And there are various scabby bits along the bottom of the car
After a strip down, I found more rust behind the wings but still pretty good overall
Off came the front panel which is in great condition apart from some surface rust
Then engine is next to come out.
Ben
#2 Anthony30
Anthony30
  • 1,466 posts
  • Local Club: N/A
Posted 06 March 2017 - 09:25 PM
Not a bad start really. :shades:
#3 midridge2
midridge2
  • 1,794 posts
Posted 07 March 2017 - 12:55 PM
Hi Ben, I would highly recommend bracing the door gaps before you remove a cill. Midgets are notorious for bending when a cill is cut off.
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 07 March 2017 - 06:10 PM
Cheers for the recommendation.
I shall be bracing :-)
#5 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 07 March 2017 - 07:50 PM
I got a bit more stripping done this afternoon.
I had a Mini to paint as well so i only got a few things done.
I removed the dashboard
Which then enabled me to remove the screen
And then i started removing the interior and took off the soft top
All pretty straightforward so far.
Ben
#6 JDImini
JDImini
  • 679 posts
Posted 07 March 2017 - 08:34 PM
Hi Ben
Internet is playing ball this evening, so great to see the progress. Nice that the first photo has Jack's mini in the background.
As you've pulled the dash out can that be repainted with black crackle paint as I don't think that was on the list. Also thinking about fuel tank is that being taken off and checked as I know with my MGB the top of the tank rusted through as it was a great water trap between it and the boot floor
Thanks Darren
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 07 March 2017 - 08:59 PM
Hi Ben
Thanks Darren
Hi Darren.
The dash had to come out to remove the screen and it will make painting the car easier too and i was actually thinking that it could do with a refresh.
I will most likely drop the tank to do the underside although I need to talk to you about that. Mainly to see if you do actually want it stripped back as discussed because it does infact look very good under there.
Ben
#8 slidehammer
slidehammer
  • 1,162 posts
  • Local Club: LSMOC
Posted 08 March 2017 - 01:49 PM
Looking forward to this project Ben
As I am sure it will be a really informative, as all the other projects you have posted on here are.
I have a bit of a soft spot for the old A series Midgets as well.
#9 Shep76S
Shep76S
  • 542 posts
  • Local Club: L&SMOC
Posted 08 March 2017 - 06:30 PM
Followed!
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 08 March 2017 - 07:23 PM
Followed!
Come and meet Ben and have a few ciders next time he's over.
#11 MrBounce
MrBounce
  • 2,614 posts
Posted 08 March 2017 - 08:47 PM
Cracking work as usual Ben - i will be taking a look at this one as I love a Midget  :wub:
#12 JDImini
JDImini
  • 679 posts
Posted 09 March 2017 - 10:31 PM
Hi Ben
Thanks Darren
Hi Darren.
Ben
Hi Ben, being a bit slow on the uptake are you talking about not stripping back the whole of the underside or just not under the fuel tank? I think the whole underside should be stripped back even if it looks OK as its the only time it's going to be done
by the way I'll try and speak to Peter May tomorrow
cheers
Darren
#13 JDImini
JDImini
  • 679 posts
Posted 10 March 2017 - 09:59 PM
Hi Ben I've spoken to Peter May and they suggest poly bushes, negative camber trunions, 400 lbs rated springs and uprated 5/8" anti roll bar so I'll be raiding the piggy bank over the weekend and you'll get a box of of nice shiny bits later in the week  :D
#14 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 10 March 2017 - 10:09 PM
Excellent.
I shall look forward to having a look when it arrives :-)
#15 JDImini
JDImini
  • 679 posts
Posted 13 March 2017 - 08:41 PM
Hi Ben,
didn't get around to ordering the kit today will try tomorrow
