Circuit diagrams (supliment dated 999) MPI (all I think) and SPI (Japan)
Electrical Diagrams 1999.pdf 1.06MB
1733 downloads (These don't need to be redrawn.)
I got this from a post Juju made in 2008. He also has the MPI workshop manual link there.
http://www.theminifo...ju#entry3367562
Here are all the wire diagrams I have redrawn from the manuals. Please let me know if any errors are found. I will fix them.
Positive Ground Diagrams
MINI SUPER - SUPER DE-LUXE - COUNTRYMAN - TRAVELLER AND COOPER -UP TO 1964.PDF 167.19K
239 downloads
MINI STANDARD AND DE-LUXE - UP TO 1964.PDF 164.59K
219 downloads
MINI SALOON, VAN, AND PICK-UP - 1964 TO 1967.PDF 153.21K
166 downloads
MINI COOPER, COOPER S, COUNTRYMAN, TRAVELLER, AND SUPER DE-LUXE 1964 TO 1967.PDF 161.22K
261 downloads
MINI SUPER DE-LUXE, COUNTRYMAN, TRAVELLER. COOPER. AND COOPER S MARK II.PDF 159.2K
203 downloads
MINI STANDARD SALOON, VAN, AND PICK-UP MARK II.PDF 150.86K
267 downloads
MINI COOPER S WITH GENERATOR CHARGING SYSTEM.PDF 119.88K
147 downloads
Moke
MINI-MOKE UP TO 1967.PDF 127.08K
46 downloads
MINI-MOKE MARK II.PDF 128.86K
69 downloads
Negative Ground Diagrams
MINI 850 DE-LUXE SALOON, VAN, AND PICKUP.PDF 176.32K
347 downloads
MINI 1000 SPECIAL DE-LUXE SALOON AND COOPER S Mk. III.PDF 169.33K
672 downloads
MINI 1275 GT.PDF 180.41K
348 downloads
MINI CLUBMAN SALOON AND ESTATE.PDF 183.01K
281 downloads
From British Leyland AKD 4935 (9TH EDITION) PUBLISHED 1976
http://www.ausmini.c...hp?f=25&t=84427 (1967 Manual from Ausmini forum)
MINI 1000 SALOON (CANADA) TO 1976.PDF 112.39K
212 downloads
MINI 850 DE-LUXE SALOON, VAN, AND PICKUP WITH ALTERNATOR & ROCKER SWITCHES.PDF 136.99K
204 downloads
MINI 1000 SPECIAL DE-LUXE SALOON WITH ALTERNATOR AND ROCKER SWITCHES.PDF 133.98K
574 downloads
MINI CLUBMAN SALOON AND ESTATE WITH ALTERNATOR AND ROCKER SWITCHES.PDF 170.7K
271 downloads
MINI 1275 GT WITH ALTERNATOR AND ROCKER SWITCHES.PDF 167.97K
350 downloads
From Rover repair manual AKM 6353 1976 - 1989
ROVER MINI WIRING DIAGRAM MINI 850 SALOON VAN AND PICK-UP 1976 ON.PDF 125.67K
285 downloads
ROVER MINI WIRING DIAGRAM MINI 1000 SALOON - MINI SPECIAL 1976 ON - PAGE 86-5.PDF 130.15K
867 downloads
ROVER MINI WIRING DIAGRAM MINI CLUBMAN, ESATE AND 1275GT 1976-ON PAGE 86-7.PDF 134.73K
205 downloads
ROVER MINI WIRING DIAGRAM MINI SPECIAL - 1977-78 PAGE 86-9.PDF 132.34K
135 downloads
ROVER MINI WIRING DIAGRAM MINI 1000 CANADA - 1977 ON PAGE 86-11.PDF 140.69K
108 downloads
ROVER MINI WIRING DIAGRAM MINI SPECIAL - 1979 PAGE 86-13.PDF 138.44K
220 downloads
ROVER MINI WIRING DIAGRAM SINGLE INSTRUMENT PACK 1984-ON PAGE 86-34.PDF 124.84K
559 downloads
ROVER MINI WIRING DIAGRAM MULTI INSTRUMENT PACK 1984-ON PAGE 86-36.PDF 135.19K
955 downloads
ROVER MINI WIRING DIAGRAM 1988-ON - PAGE 86-49.PDF 168.13K
1264 downloads
ROVER MINI TWIN GAUGE INSTRUMENT PACK WITH INTEGRAL VOLTAGE STABILISER - PAGE 86-50.PDF 165.36K
327 downloads
ROVER MINI TRIPLE GAUGE INSTRUMENT PACK WITH INTEGRAL VOLTAGE STABILISER - PAGE 86-50.PDF 167.65K
671 downloads
ROVER MINI WIRING DIAGRAM TURBO MODEL - PAGE 86-53.PDF 98.95K
110 downloads
From Rover repair manual AKM 7169 1992 - 1996
ROVER MINI POWER DISTRIBUTION - CARBURETTER MODELS - WIRING DIAGRAMS PAGE 4.PDF 61.58K
1181 downloads
ROVER MINI POWER DISTRIBUTION - SPI MODELS - WIRING DIAGRAMS PAGE 6.PDF 58.28K
1189 downloads
ROVER MINI EXTERIOR LAMPS AND HORN - WIRING DIAGRAMS PAGE 8.PDF 67.38K
991 downloads
ROVER MINI DRIVING AND FOG LAMP CIRCUITS WOIRING DIAGRAMS PAGE 10.PDF 47.58K
664 downloads
ROVER MINI REVERSE LAMPS, BRAKE LAMPS AND HEATED REAR WINDOW CIRCUIT WIREING DIAGRAMS PAGE 11.PDF 51.41K
529 downloads
ROVER MINI DIRECTION INDICATOR AND HAZARD WARNING -WIRING DIAGRAMS PAGE 12.PDF 58.21K
682 downloads
ROVER MINI INSTRUMENTS - WIRING DIAGRAMS PAGE 14.PDF 58.11K
683 downloads
ROVER MINI INTERIOR LAMP CIRCUIT - WIRING DIAGRAMS PAGE 16.PDF 48.76K
311 downloads
ROVER MINI HEATER & AUTOMATIC GEARBOX SELECTOR ILLUMINATION CIRCUITS - WIRING DIAGRAMS PAGE 17.PDF 41.58K
264 downloads
ROVER MINI ENGINE MANAGEMENT - WIRING DIAGRAMS PAGE 19.PDF 75.88K
664 downloads
ROVER MINI ANTI-THEFT ALARM - WIRING DIAGRAMS PAGE 20.PDF 51.57K
382 downloads
ROVER MINI WASH WIPE CIRCUIT - WIRING DIAGRAMS PAGE 22.PDF 47.06K
377 downloads
ROVER MINI AUXILIARY COOLING FAN AND BRAKE TEST CIRCUITS - WIRING DIAGRAMS PAGE 23.PDF 47.43K
408 downloads
ROVER MINI RADIO CASSETTE PLAYER - WIRING DIAGRAMS PAGE 24.PDF 49.87K
413 downloads
ROVER MINI SUN ROOF CIRCUIT - WIRING DIAGRAMS PAGE 25.PDF 42.21K
142 downloads
ROVER MINI HEADLAMP LEVELLING CIRCUIT (GERMANY) - WIRING DIAGRAMS PAGE 26.PDF 45.71K
158 downloads
BMC HORNET AND ELF repair manual AKM 4062 D
The full manual AKM 4062 D can be found on the ausmini forum courtesy of Mick
http://www.ausmini.c...hp?f=25&t=87229 (link update due to Viz139 pointing out that it was broken)
HORNET AND ELF - 1961 TO 1964.PDF 170.16K
59 downloads
HORNET AND ELF - 1964 TO 1967.PDF 144.92K
49 downloads
HORNET AND ELF - 1967 ONWARDS.PDF 153.84K
79 downloads
INNOCENTI DIAGRAMS FOUND AT http://www.miniminor.com/index.htm
CENTER BINNACLE
INNOCENTI MINI 1000 - MINIMATIC.PDF 185.41K
52 downloads
INNOCENTI MINI 1000.PDF 174.9K
76 downloads
INNOCENTI MINI 1001.PDF 171.12K
46 downloads
INNOCENTI MINI MINOR MK1.pdf 166.73K
43 downloads
INNOCENTI MINI MINOR MK3.PDF 168.1K
52 downloads
INNOCENTI MINIMATIC.PDF 175.74K
26 downloads
INNOCENTI MINI t 1000 (TRAVELLER).PDF 169.85K
36 downloads
SPEEDOMETER & TACHOMETER (THE "COOL" DASH)
INNOCENTI MINI COOPER 1000 MK3.PDF 182.41K
122 downloads
INNOCENTI MINI COOPER 1300 EXPORT.PDF 169.16K
151 downloads
AUSTRALIAN Workshop Manual Supplement
PublicationTP 759 A Issued May 1969 AKD 4935 A
The diagram on page 18 of Section n.8 of the PDF I have is 95% blank.
It covered Mini Deluxe and several more but that is all I can see.
If anyone has this page I will redraw it as well.
AUSTRALIAN MINI STANDARD SALOON AND VAN.PDF 152.35K
104 downloads
AUSTRALIAN BMC MOKE WITH ALTERNATOR.PDF 107.93K
55 downloads
AUSTRALIAN MINI AND BMC MOKE WITH GENERATOR.PDF 136.68K
46 downloads
AUSTRALIAN MINI 1000 K, 1100 STD, VAN, MINI MATIC (1100), COOPER S (WITH ALTERNATOR).PDF 130.77K
109 downloads
AUSTRALIAN MINI COOPER S WITH GENERATOR CHARGING SYSTEM.PDF 119.73K
69 downloads
These are diagrams for SPI 1995-1996
These were mostly reverse engineered by viz139 from his 1995 Equinox. (All questions on these should be directed to viz139)
Also a few he has collected that were not already here.
I notice that the .jpg and .bmp files are not showing as clear as I would like here. You may want to PM vis139 for a clearer copy.
SPi 95-96 24 Fuse Engine Bay Fuse Box.pdf 9.23K
472 downloads
SPi 95-96 HARNESS ENGINE BAY.jpg 94.02K
364 downloads
SPi 95-96 ALARM.jpg 51.97K
351 downloads
SPi 95-96 ECU & COOLING.jpg 58.9K
351 downloads
SPi 95-96 CHARGE & STARTING.jpg 63.32K
326 downloads
SPi 95-96 HEADLIGHT BRAKE REVERSE FOG LIGHTS.jpg 60.65K
338 downloads
SPi 95-96 INDICATORS & HAZARD.jpg 43.6K
326 downloads
SPi 95-96 INSTRUMENTS.jpg 42.46K
295 downloads
SPi 95-96 POWER DISTRIBUTION.jpg 62.12K
308 downloads
SPi 95-96 WIPERS STEREO HEATER INTEREIOR BRAKETEST.jpg 40.57K
245 downloads
Headlamp level switch.bmp 528.39K
68 downloads
ERA Turbo Installation Wiring.jpg 43.89K
135 downloads
Edited by Mike L, 16 April 2019 - 04:48 PM.
