What Spec Is Required To Get A 180 -200 Hp Turbo Motor?
Posted 14 February 2017 - 08:23 PM
Posted 14 February 2017 - 08:31 PM
Posted 14 February 2017 - 09:24 PM
Posted 14 February 2017 - 10:09 PM
Posted 14 February 2017 - 11:03 PM
Bottom end and box will be the same specs though.
Posted 14 February 2017 - 11:16 PM
A Turbo engine on the other hand would require nowhere near the RPM to make 200hp. You don't need a fancy crank and rods to break the 200hp barrier, but the parts you use must be spot on and the engine well put together.
A GT17, GT20, hell even the old T3 will do it. A decent head, phase 2 cam, efficient (not just big) intercooler, the cast Omegas will take the boost, but if it's a track or race car used under boost for prolonged periods go with the forged.
Phil.
Posted 15 February 2017 - 05:58 PM
To get 200hp from a NA A-Series might be possible but the RPM required to do so would require a very serious bottom end if it was to last any time at all.
Phil.
I use the die cast omegas on a big powered track car 20 mins a race, they have been great no probs for me,
167 hp atw
agreed about the bottom end through,
my forced inducted racer eats my pals 16v bmw mini alive...
Posted 15 February 2017 - 06:13 PM
Phil.
Edited by Turbo Phil, 15 February 2017 - 06:15 PM.
Posted 15 February 2017 - 06:34 PM
That's good to hear about the cast Omegas, I can't fault the ones I've used either, though it's never under boost for continuous long periods.
Phil.
Well again my car is under boost for long periods at at 7300 max revs it does 17psi, so far so good with the die casts
Posted 15 February 2017 - 07:44 PM
Posted 15 February 2017 - 08:03 PM
Posted 15 February 2017 - 08:41 PM
Posted 16 February 2017 - 07:14 AM
Posted 17 February 2017 - 08:28 AM
If you check out 'boostedbois' on youtube they're putting 30PSI through Chinese ebay turbos on b18's (650bhp) and they're taking the abuse.
Posted 17 February 2017 - 11:50 AM
Aye, cc's don't really matter with a blower. Often less is more as it makes it easier to get the compression ratio down for the extra boost.
Good Q about the GT17, what models were they fitted to?
Found this list, nothing on A/R or trim but the part codes might tell you.
