Oil Pressure Switch Failure?
Best Answer Spider , 12 February 2017 - 08:55 AM
The Switch should be Closed with no pressure, ie, without the engine running. If you have an Open Circuit before cranking, the Switch is cactus.
Go to the full post
30 replies to this topic
#31 phildward
phildward
  • 93 posts
Posted 23 March 2017 - 01:28 PM
Oil pressure test results:
Cold cranking, plugs in.  Delay then approx 60 psi
Cold start, fast idle, approx 65 - 70 psi
Warm at idle, approxe 60 psi
Hot full beans, approx 70 psi
Thread size 1/8 NPT
I think not bad for a 120k miles original engine with thin oil in it?
