How Do I Make Wired Edges?
5 replies to this topic
#1 Frost Auto
Frost Auto
    Formally known as Frost
  • 75 posts
Posted 09 February 2017 - 07:21 AM
Step 1
Mark out edge to be wired, with approx 8mm extra for making the wired edge. Use G104 Aviation Snips to cut to the 8mm line.
Step 2
Using Swage fit the jenny wheels to throw up an edge along the marked line (about 45 degrees).
Step 3
Use the wiring wheels to form a U shape along the crease previously formed, the work piece will have to be tipped to so as to come down the face of the top wheel.
Step 4
Insert the wire in the U and trap it by using a hammer on the open edge at approx 150 mm intervals.
Step 5
Put the closing wheels on the machine and set the gauge approx 6mm behind the top wheel.
Step 6
Run along the length of the wired edge closing it sufficiently to securely trap the wire all the length.
Step 7
Set the closing wheel to one thickness of metal (about 1mm) and run down the edge again to give a full length, even finish.
#2 Richie83
Richie83
  • 1,495 posts
Posted 09 February 2017 - 09:08 AM
Could you add some photos? Just a suggestion.
#3 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 09 February 2017 - 10:30 AM
Erm......What's a wired edge?
#4 panky
panky
  • 1,785 posts
Posted 09 February 2017 - 10:40 AM
The edge of the sheet metal is formed around a length of wire to strengthen it - think of the wing edges on an old 30's car with big flowing wings.
#5 jakejakejake1
jakejakejake1
  • 644 posts
Posted 09 February 2017 - 11:01 AM
Something like this:
It adds strength to the edge of a panel, plus it looks quite nice if done properly.
#6 Frost Auto
Frost Auto
  • 75 posts
Posted 09 February 2017 - 12:34 PM
008-types-of-bends-edge-and-notch-1-728.
