Petrol Tank Breather Help
13 replies to this topic
#1 carts60
carts60
  • 1,007 posts
Posted 07 February 2017 - 09:51 AM
Hi All,
The car has been sat over winter in the garage and the smell of fuel is crazy.
Having given the lines a full once over from front to back and with the engine running etc there are no leaks and I've basically sourced the issue to the fuel breather hose which in my case comes off the tank and exits under the car, running along the subframe.
I assume because its an 'open' vent with no filter etc it just releases fumes constantly causing the fumes to constantly be evacuated.
Is there a way to stop this without circumventing the intention of the vent?
Add an in-line filter? Add a non mini valve of sorts?
Any suggestions?
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 07 February 2017 - 09:55 AM
How warm is it in the garage?
Is the boot floor dry?
#3 carts60
carts60
  • 1,007 posts
Posted 07 February 2017 - 09:58 AM
Freezing in the garage - same temp as its been outside.
Yes boot floor is dry - no leaks
#4 Its a min
Its a min
  • 284 posts
Posted 07 February 2017 - 05:43 PM
I had a similar problem with mine. It turned out that the overflow/breather pipe had split where it connected to top of the petrol tank and was practically hanging off. The petrol fumes were filling the boot and making their way into the car.
Hope this helps.
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 07 February 2017 - 05:53 PM
I trust the floor is dry when it is running...- sticky float in carb...
#6 carts60
carts60
  • 1,007 posts
Posted 07 February 2017 - 09:12 PM
To be clear, the fumes I can smell are in the garage rather than in the car which is why I am so sure its the breather as the hose exits outside the body of the car, pumping the fumes into the garage.
Also concerned due to the fire hazard seeing as petrol fumes are just as flamable as the liquid - if not more so.
I'll have to check the top connector but I think its fine.
@bpirie - yes, floor is dry when running - carb functions perfectly. Not getting any overflow from the float bowl or otherwise.
If I can't get to the bottom of it i am going to try a charcoal filter or something similar to try to capture (or at least mask) the fumes. If that doesn't work, maybe try another method such as routing the breather back into the filler neck.
Edited by carts60, 07 February 2017 - 09:15 PM.
#7 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 07 February 2017 - 09:45 PM
Routing it back to the filler cap would render it pointless as the system would pressurise
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 09 February 2017 - 07:50 AM
The issue would not be pressurisation, but the creation of a vacuum as the engine used the fuel. This would lead to fuel starvation as the pump would start to struggle to suck the fuel from the tank.
#9 monkey
monkey
  • 1,382 posts
Posted 09 February 2017 - 09:04 AM
"Vacuum" that's the word I was looking for! I knew I didn't mean pressurise lol
#10 whistler
whistler
  • 1,791 posts
Posted 09 February 2017 - 10:00 AM
You used to be able to use vented petrol caps years ago which would negate the need for the tank breather pipe. Anyone know if they are still available?
#11 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 09 February 2017 - 10:06 AM
All fuel caps are vented except injection ones iirc (green internals rather than red)
#12 whistler
whistler
  • 1,791 posts
Posted 09 February 2017 - 10:11 AM
Then the tank doesn't need venting then or does it?
#13 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 09 February 2017 - 02:40 PM
I have had a simular situation. I had my fuel line remove at the carb for about the 2 weeks as the car is currently of the road.
I noticed a bad smell of fuel and it turned out it was leaking from the open pipe end and onto the floor.
so i reconnected it and did the clips up tight.
anyway came home from work last night thinking it smells really bad, now it had pushed the hose off from the outlet of the fuel pump and was dripping onto the concrete floor.
tightened it all up last night, check before work and leak free.
funny thing is it not been used since xmas so i can only guess expansion/contraction due to the temperature.
any ideas?
#14 JXC Mini GT
JXC Mini GT
  • 842 posts
Posted 10 April 2017 - 07:54 PM
Grateful for advice on whether I can remove the tank vent pipe if I have a vented filler cap as I seem to get the odd drop of fuel dripping out of the vent pipe after parking up after some spirited driving.
