Mini Van " Shly"
37 replies to this topic
#1 Haggis#15
Haggis#15
  • 27 posts
Posted 05 February 2017 - 10:37 PM
Hello, heres my van, these picture were taken buy the guy i got it off, he i did a bit to it and then i got it oct 2015 ish
#2 Haggis#15
Haggis#15
  • 27 posts
Posted 05 February 2017 - 10:41 PM
this is how i got it, 90% welding done so it was told ....
#3 Haggis#15
Haggis#15
  • 27 posts
Posted 05 February 2017 - 10:56 PM
here what i found, when i went to fit the doors the A panels welded over the ones and the healboard was sheeted over too
#4 Haggis#15
Haggis#15
  • 27 posts
Posted 05 February 2017 - 11:20 PM
#5 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 06 February 2017 - 06:53 AM
Nice to see another van getting some love, I will be keeping an eye on this build...
#6 Haggis#15
Haggis#15
  • 27 posts
Posted 06 February 2017 - 08:48 PM
here's more of the dreaded rust i found
#7 Haggis#15
Haggis#15
  • 27 posts
Posted 06 February 2017 - 08:55 PM
so i decided to renew the whole floor and heal board
#8 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 08 February 2017 - 10:55 AM
There's nothing worse than having to peel back someone else's poor workmanship,good luck will be watching
#9 bpirie1000
bpirie1000
  • Area Managers
  • 2,279 posts
  • Local Club: Amoc
Posted 08 February 2017 - 01:49 PM
Van tactic another saved... good luck and enjoy.... best advice is
'don't get frustrated walk away.. always something else can be done...'
#10 Haggis#15
Haggis#15
  • 27 posts
Posted 08 February 2017 - 07:59 PM
i had to repair theses strengthening panels before i put the new floors in
#11 Rocket.
Rocket.
  • 1,441 posts
Posted 08 February 2017 - 08:02 PM
Nice work always annoying undoing bodge jobs but at least you'll know it's been done properly!
Good luck with it!
#12 Haggis#15
Haggis#15
  • 27 posts
Posted 08 February 2017 - 08:04 PM
cheers, I've been frustrated alright and impatient loads, but yeah your right the key is to give a break and do something else that needs done or go to car show that usual kicks it back in
#13 Haggis#15
Haggis#15
  • 27 posts
Posted 08 February 2017 - 08:05 PM
Good luck with it!
cheers yeah you get piece of mind but now I'm buying everything new because its turning out so good so it cost me a fortune lol
be kool when its done tho
#14 Haggis#15
Haggis#15
  • 27 posts
Posted 08 February 2017 - 08:14 PM
tied in the healboard and towboard in and fitted new strengthening plates for the front subframe in 4mm plate this later will be a bad move as i bought poly bush subframe mounts and the bolt bracket bolts aren't long enough to go through the plate and mount so i had to fit standard ones (lesson learnt)
#15 Rocket.
Rocket.
  • 1,441 posts
Posted 08 February 2017 - 08:30 PM
Good luck with it!
I think this is the case with most restorations! I know it certainly is with mine
