Drill And Tap Cast Iron Turbo Housing
18 replies to this topic
#16 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 01 February 2017 - 09:44 AM
I just thought of something. Would using a centre punch be likely to crack the casting or am I over thinking it?
I doubt it will crack the housing but you're going to find out :D . If you're worried, drill a 2mm pilot hole just into the casting face (while its still rough and will stop a small drill bit from sliding) to act as a centre before you file the flat on it.
#17 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 13 February 2017 - 08:22 PM
Job done. No pilot hole. Dropped centre punch down back of engine onto undertray so just drilled and tapped. No probs no leaks as far as I can tell. mr muscle did the trick and no limp mode so thanks for your help guys.
#18 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 13 February 2017 - 09:41 PM
Its great when a plan comes together. Well done.
#19 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 14 February 2017 - 03:20 PM
good news
