So have a bit of a smoking problem... some background
1275cc pre A+ block
12G940 head
HIF44 carb
engine done unknown kms. rebuilt late 1990s. I'd estimate 50,000km
Engine removed from car ~4 years ago, was running fine.
Removed head ~3 years ago to give it a once over- new valve stem seals, decoke, re-lap valves, new head gasket (payen BK450) and stud kit (http://minispares.co...c/C-AHT280.aspx and http://minispares.co...s/C-AHT281.aspx)
cleaned the bores/piston crowns while head was off (now realise this shouldn't have been done).
reassembled, torqued head stud nuts up to 65lb/ft as per minispares link, with oil. Then I read here http://minispares.co...-nut-washer-kit that 45lb/ft is recommended for rover/payen.
Penrite HPR-30 oil in the engine
prior to first start I reverse primed the oil pump and squirted some oil into the combustion chambers.
smokes fairly badly once warmed up - car isn't registered so can't be driven, so all tests done while stationary. Smokes mostly on throttle, not over run. otherwise ran fantastically. oil pressure 75 psi cold, 50 psi @ idle when hot.
there was some bubbling under the 5/16 ARP head bolt. the thread does not go through the head into a water gallery.
removed rocker cover cap and some blue smoke visible chuffing out.
only has one breather on transfer case. tested with breather to atmosphere and fed to carby, no change.
prior to headgasket/head work, engine never smoked.
so.....
ripped the head off
photo time.
plenty of oil under on the surfaces of the head gasket on the pushrod side of the engine.
lots of oil in the inlet ports
bores look good, no lip at top of bore.
barely any movement of piston in bore at TDC, BDC, or middle of travel.
there was a ~1.5cm diameter pool of oil on each piston when I removed the head. no photo sorry!
compression test prior to removing head was 150 on #1, 190-200psi on #2-#4. #1 came up to 170 after squirting some oil in the chamber.
Praying it's not rings (all four to go at once???), and looking at the head gasket oil hoping that it was over tightened and warped? possible?
I think first test will be new gasket/head studs etc, and retorque up to 45lb/ft, and retest, before stripping engine!
Any input thoughts from people many tims more knowledgable than myself?
