Valve Guides How Do You Know If You Need To Replace
16 replies to this topic
#1 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 26 January 2017 - 03:35 PM
How do you check these, do you just feel for movement? Got my head in getting work done and they said the guides seem OK, how are they checked?
Are they easy to diy replace if you have access to a press?
They said if I want them replaced its £5 per a guide (plus cost of the guide) to press out and new one in but said I don't need to replace them
#2 nicklouse
  • 18,579 posts
Posted 26 January 2017 - 03:51 PM
if I was changing guides I would be changing valves as well.
guides will need reaming to size after fitting and seats recut.
#3 Spider
  • 14,843 posts
Posted 26 January 2017 - 07:42 PM
An easy way is to fit an unworn valve and measure the wobble with a Dial Gauge.
Personally, I rarely bother checking them, i just replace them as a matter of course.
In addition to the Reaming that Nick mentioned, you'll also need to get the Seats re-cut following this as the new guides may not be on the same centres as the old ones. Again, all standard head reconditioning stuff.
#4 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Unless the guides are fairly new phosphor bronze ones I would get them changed and reamed to size as a matter of course. I ordered a set from mini spares, got them sent direct to the machine shop and they fitted them.
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 26 January 2017 - 08:08 PM
The iron type guides are fine for most applications running the road spec valves, & are only about £1.50 a piece.
Phil.
#6 Spider
  • 14,843 posts
Posted 26 January 2017 - 08:15 PM
Phil.
They also withstand 'abuse' way better.
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 26 January 2017 - 08:47 PM
Yep ! Folk just seem to think they must have the bronze ones, just like they must have double valve springs to.
Phil.
#8 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 26 January 2017 - 09:43 PM
Get a mic on the valve stems as well if you plan to reuse them
#9 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 27 January 2017 - 12:23 AM
Is £5 per a guide an OK price for fitting them? Thanks
#10 Spider
  • 14,843 posts
Posted 27 January 2017 - 12:31 AM
IMO, quite cheap!
#11 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 27 January 2017 - 07:08 AM
That's a fair price, you can get it done cheaper but that's not extortionate
As mentioned above though they will need sizing and the valve seat will need recutting
#12 EOA
EOA
    Starting My Mini Up
  • 1 posts
Posted 27 January 2017 - 08:08 AM
There are tolerances in the workshop manual, the bore of the guide and the valve stem need to be measured to see if the clearance is within limits. If they are do not change them, there is a long way between new and Knackered. "If it aint broke don't fix it"
#13 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 27 January 2017 - 10:04 AM
£5 a pop is not bad .. I've done it myself at home a good few times using an old guide and a cut down valve welded together as a removal tool.  I seem to remember it taking me an evening to hammer out the old ones and put the new ones back in ...so £40 seems good value
As to having the seats recut I've never found a problem with just lapping either new or existing valves into seats after guide replacement, same for reaming or sizing...maybe I've just been lucky.
If you are not that confident then get an engineering company to do it, keep in mind they may and try to 'up-sell you' to stuff not really needed ...if you think that's the case just ask on here...
Edited by DomCr250, 27 January 2017 - 10:05 AM.
#14 panky
panky
  • 1,790 posts
Posted 27 January 2017 - 10:13 AM
I did it myself too, a mate turned me a tool and the old ones came out quite easily with a few stout thumps. I put the new ones in the freezer for half an hour before fitting and again the went in nicely. The cast guides dont need reaming and I didn't need to re-cut the seats, may have been lucky but a short session grinding them in was all that was needed. Just remember to drive the old ones out from the top and the new ones go in the same way - and make sure the guide is left protruding the required amount.
£5 a guide does seem a good price though if you dont fancy DIY.
#15 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 27 January 2017 - 10:46 AM
Always, always ream the guides. They're an interference fit and pressing them into the head means they do need to be reamed to ensure correct clearance. You may get away with it as mentioned above, but I personally wouldn't chance it.
You also must recut the seats, no if's not but's, to ensure proper seating of the valve.
You can knock the old guides out with a punch and hammer, but a press is better and they should be pressed back in to avoid distortion.
You're just asking for trouble if you don't do things properly.
Phil.
Edited by Turbo Phil, 27 January 2017 - 10:50 AM.
