Chunky Tyres Than Work Well On The Road
29 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 23 January 2017 - 08:37 PM
Would like some rally looking tyres 13 x7 that still have good performance the road. Am I looking for something that does not exist?
#2 nicklouse
  • 18,581 posts
Posted 23 January 2017 - 09:04 PM
Yes as when we want grip on roads we go as close to slicks as we can. And leave the knobblies for the dirt. If there is a bit of both then soft knobblies that will not last that long.
You may also have issues with that wheel size.
#3 Cooperman
  • 23,278 posts
Posted 23 January 2017 - 09:15 PM
There are no 13" 'knobbly' tyres that will fit a Mini.
However, if you get a set of 12" wheels Maxsport Tyres do a forest tyre in 145/70 x 12 which would be ideal. The maximum wheel width should be 4.5", which is the standard width, so easy and not expensive. The tyres, in an optional hard compound are around £72 each. They won't last to long on dry tarmac though, but they are great on gravel, mud and snow.
#4 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 January 2017 - 09:35 PM
This'll be for an amc cub moke, they have 13 inch wheels, I was going to raise it up a bit and put some slight neg cam on the front
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 January 2017 - 09:53 PM
Attached File  bmc-mini-moke-thumb.png   165.13K   34 downloads
I know its quite hard, but what size wheels do you reckon these are
#6 nicklouse
  • 18,581 posts
Posted 23 January 2017 - 10:14 PM
Link to original picture? Might be easier to see.
#7 nicklouse
  • 18,581 posts
Posted 23 January 2017 - 10:48 PM
Ok that is a Moke that you are showing. A different beast. That could even have 14" wheels those that did also had longer radius arms.
Spider should be along soon and will be able to tell you exactly what that has.
#8 mab01uk
mab01uk
  • 12,413 posts
Posted 23 January 2017 - 11:08 PM
Early Australian Mokes had 10 inch wheels like the British version but changed in 1969 to 13 inch diameter. This involved longer rear radius arms (as the tyres were not low profile) and wider bodywork arches. The standard 13 inch wheels were plain pressed steel but the 1977 ‘Californian’ model came with 8-spoked steel wheels in white.
Edited by mab01uk, 23 January 2017 - 11:10 PM.
#9 Spider
  • 14,843 posts
Posted 23 January 2017 - 11:44 PM
I fitted these Dunlop Rally Tyres to the Wife's Moke about 5 years ago
Done over 10 000 km on them so far and they have LOTS of tread left on them, despite being a 'Medium - Soft' Compound. Very happy with them and while they can be heard on sealed roads, they aren't 'noisy'.
#10 Spider
  • 14,843 posts
Posted 24 January 2017 - 12:12 AM
They are 13" wheels (as mab01uk has touched on), but I'm not 100% sure on the width of those particular ones. I have seen that car in the flesh but had different wheels when I saw it (in 2009).
<Edit: I don't know all the suppliers in the UK (Far from it!), however, I know Demon Tweaks have reasonable on-line listing for Tyres
http://www.demon-twe...mpetition-tyres
However, as you have an AMC Cub, I'm not sure if these have Mini or (Big Wheel) Moke Trailing Arms. As mab01uk has pointed out, the Big Wheel Moke uses a unique and longer Trailing Arm than the Mini to accommodate these bigger wheels, so. before spending money on wheels, check what you have. A quick simple check is to have a look at the Shock Mount Stud, if it's in the other end of the Stub Axle (for the wheel), then it's a Mini one, if it's about 3" further up the arm from the Stub Axle, then it's a Big Wheel Moke one. >
Edited by Moke Spider, 24 January 2017 - 12:20 AM.
#11 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 24 January 2017 - 08:54 AM
Like the pic. what size wheels are they on?
#12 Spider
  • 14,843 posts
Posted 24 January 2017 - 09:02 AM
tLike the pic. what size wheels are they on?
Standard Moke Californian Wheels - 13" x 5.5"
The tyres are a 13R70 - 185, from memory, Dunlop SP85
http://www.dunloptyr...2&from=nPerPage
#13 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 24 January 2017 - 12:58 PM
Don't suppose you have a side on pic of the tyres on the car
#14 nicklouse
  • 18,581 posts
Posted 24 January 2017 - 01:37 PM
will not fit on your Cub if you still have Mini rear arms.
#15 Spider
  • 14,843 posts
Posted 24 January 2017 - 06:04 PM
Not on file, but will get one.
