Mk1 Austin Cooper Vin / Chassis Number / Engine Number Locations
8 replies to this topic
#1 34banwell
34banwell
  • 16 posts
Posted 23 January 2017 - 11:26 AM
I was wondering if anyone knows on an 1963 Austin Cooper 997cc, where they are located and what the plates would like for chassis numbers and engine numbers etc.
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 23 January 2017 - 01:19 PM
Chassis plate should be located on radiator surround, should start with CA2S7-***
body number usually on front slam panel but easily lost when any repairs done,
FE number should be on inner wing where the radiator surround is spot welded to the inner wing.
My 1962 mk1 also has a number on the drivers side floor pan, but again easily lost during repairs.
#3 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 23 January 2017 - 06:44 PM
The link below should take you to a good engine bay shot of a Mk 1 Cooper S showing the items you asked about. Many of the other details are not correct for a 997 Cooper as it wouldn't normally have a brake servo or oil cooler etc.
https://www.swva.co....90&a=c&zc=1&s=1
As mentioned above, the chassis plate and FE number tag are to the right of the radiator as you look at the picture.
There is a close up picture of the chassis plate although it is on upside down
The body number tag is on the front panel by the horn mounting.
#4 34banwell
34banwell
  • 16 posts
Posted 24 January 2017 - 01:06 PM
Thanks Guys
Also, I was just checking the chassis and engine numbers on my V5 against the heritage certificate I have just received.
I think on the V5 the engine and chassis numbers have been entered the wrong way around.
On V5 it reads:
engine number - C-A257439780
Chassis number - 9FSAH23659
Heritage cert reads:
Engine number - 9F-SA-H/23659
Chassis Number - C-A2S7/439780
I am confused, which is correct?
anCan anyone help?
#5 ace01
ace01
  • 457 posts
Posted 24 January 2017 - 01:16 PM
That is a common problem.  The heritage certificate is obviously correct, but many records were transferred from written copy when the DVLA went computerised and as a result 7s became Ss and much more.  It does not detract from either the value or authenticity of a car.
#6 34banwell
34banwell
  • 16 posts
Posted 24 January 2017 - 02:32 PM
Thanks ace01
I will have to buy another chassis plate now though as I have had it stamped incorrectly.
What type of chassis plate would be correct for the car? And does anyone know who supplies them. I think I had an incorrect/later chassis plate anyway.
#7 pdaykin
pdaykin
  • 587 posts
Posted 24 January 2017 - 08:32 PM
Minimail can supply and stamp the chassis plates
#8 mab01uk
mab01uk
  • 12,412 posts
Posted 24 January 2017 - 11:57 PM
As said Minimail can stamp and supply the correct Chassis plates, order form & details here:-
http://www.minimail....sis-vin-plates/
#9 62S
62S
  • 1,243 posts
Posted 25 January 2017 - 09:58 AM
34banwell you have a PM
