Coachbuilt Oyler Contessa (The Countess)
300 replies to this topic
#91 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 12 July 2017 - 09:31 PM
Thanks for the comments folks! just going to stick with P.B for the moment! till they pull the plug
on my 3rd party hosting, at the moment I pay for AD free, but as far as paying $399 for full Boonah :bah:
Anyways on with the job, been working away at it,
got engine cleaned up and ready for prepping and paint,
bulkhead cleaned up ready for primer and paint, most of it had been coated in Cadulac so only a
couple of bits surface rust which was removed and treated with De ox before priming,
Engine compartment primed, seam sealed and painted!, lower areas and under the wings were first
done with stone chip then primed and painted, have found some spray on Bitumen to hopefully
emulate the original Coach-builders finish (blooming messy stuff so we will see) certainly the
original worked well in keeping the rust at bay.
Started cleaning up parts and repairing wiring loom and refitting some, front subframe
cleaned up painted and refitted! need the space in garage.
inside boot primed and painted, got to be one of the most difficult parts to paint, especially with a
full size gravity feed HVLP spray gun, Happy days!
Engine cleaned up primed and painted, going by what paint was still on it and being an 1098cc I believe
this is how it was painted originally, just got to replace the driveshaft and gear linkage seals they
were not leaking but think it would be sensible to replace them.
More to follow thanks for looking.
#92 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 July 2017 - 10:46 PM
lovely stuff
#93 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 July 2017 - 10:52 PM
Still great quality, very nice to see.
#94 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 17 July 2017 - 09:53 PM
Once again thanks for the comments! its good to see that by the amount of views
this gets the likes that people find it interesting  :highfive: the jobs to do get less
each day!! at the moment I am just waiting on a call to go and pick up the seats
that have had some work done, whilst at MCR day at Beaulieu  I had a look at the
Maniflow stand! and after a few phone calls ect this arrived last week,
just exactly what I had in mind, although probably not exactly the same as what was originally fitted
but as good as, did try to source one localy but was not impressed by what the companies
I looked at were offering,
Next job was to prepare the inside for painting,
As when all the trimming is done and all other interior parts fitted ,(no painted parts will be seen)
so the painting was for protection only, 3coats of Lechlar epoxy primer followed by3coats wet on wet
of Damask Red top coat,
All masked up and started dry block sanding the Epoxy primer which was applied a couple of months
ago got it at a reasonable height to save my 70year old knees  ;D
1 job I have been putting of for ages cleaned the Cadulac wax treatment from the front part of inside
bonnet it had done its job very well with just a little surface rust on one of the buffer pads,
biggest job was removing the glue that had been used to stick sound deadning pad on,
in fact most of the work on painting the inside of the car has been cleaning of glue :bah:
Going to over to Tatton Park on Wednesday so going to see about getting Vinyl material for
roof covering from a place that Panky on here recommended some time ago hopefully another part
sorted.
Thanks for looking more to follow.
#95 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 July 2017 - 09:56 PM
Lots of primer to flat.
I feel your pain.... :lol:
Looking epic as usual.
I'm looking forward to seeing the refreshed interior  :gimme:
#96 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 17 July 2017 - 10:03 PM
Great progress, always enjoy your updates. Keep them coming.
#97 johnR
johnR
  • 2,297 posts
Posted 18 July 2017 - 12:25 PM
The engine looks great, couple of questions as I'm about to restore a 1275 motor: what did you clean it with and did you paint it assembled or separate parts? Third and last question,what paint did you use? thanks, JohnR
#98 wingnut
wingnut
  • 463 posts
Posted 18 July 2017 - 03:44 PM
Thats looking great
#99 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 18 July 2017 - 09:39 PM
I used products from Frost Restoration Products! namely Marine Degreaser, Por15 metal prep, then a bit of work with wire brush
ect, Paint used VHT primer then VHT black engine paint , it was painted as is less distributer and oil pressure switch!
still got to paint bottom of gearbox casing when I get it back on engine crane. Its only done 25k so had no oil leaks!!!
From memory and what was found on cleaning I believe the whole thing was painted black originally, being a 1098cc,
hope that helps.
#100 johnR
johnR
  • 2,297 posts
Posted 19 July 2017 - 02:50 PM
Many thanks - I'll look into those products
#101 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 22 July 2017 - 10:58 PM
With the recent developments on photos and being recommended not to use PB I would try
and use Imgur so hopefully, a couple of photos on this weeks progress,
got all the epoxy primer flatted and put on another 3coats of primer/surfacer,
once this is flatted top coat time!
picked up seats from upholsterer today turned out amazing, been away for a
couple of days this week so tried a couple of places for vinyl roof material and
carpet materials not quite got anything good enough to match.
More to follow! (hope photos work)
#102 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 July 2017 - 11:19 PM
Those seats are amazing!
#103 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 23 July 2017 - 05:21 AM
Still looking good and you'll also be happy the pictures work. :proud:
#104 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 23 July 2017 - 08:46 AM
Stunning seats!  =]
#105 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 23 July 2017 - 11:31 AM
Those seats look armchair comfy!!
