Coachbuilt Oyler Contessa (The Countess)
300 replies to this topic
#76 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 07 May 2017 - 11:30 AM
On a bit of a break from this at the moment and kind of missing it so thought
a bit of an update would help! I did a bit of digging about on the history of
the Contessa after getting some details back from DVLA, called at the
address of first owner unfortunately he passed away a few years ago so
drew a blank with that, have others to try when I get some time , did however
get the rear seat back from the upholsterer did a real job on it and is getting
some other work from me on it ,started stripping of some of under bonnet
ancillaries ready for engine removal, and cleaned up tops of inner wings,
 they are in very good condition under the Cadulac have decided that the tops will be
finished in the body colour and not recoated with Cadulac type material with the
lower part redone with under wax type material decision on what to use under
consideration, gave it all a coat of epoxy primmer for the moment,
then started cleaning up rear parcel shelf it was in pretty good condition despite
having had the speaker holes cut out there was some surface rust round them,
once I got the wax treatment removed from behind the fuel tank area it showed
up the work that was done to strengthen the rear seams when it was de seamed,
 the rest of the boot floor cleaned up small bit of surface rust in corner of
battery box will be further checked from underside once the rear subframe is
removed , the rear of the spare wheel housing had what appears to be a pool
of the black ecoat material which is bl**dy hard seem to remember seeing something
like it back in the day , with the boot floor being in exalt condition for a forty year old
gave it a couple of coats of epoxy primer for now will be all redone when it comes
to the refinishing phase. All for now  thanks for looking and comments.
#77 JC T ONE
JC T ONE
  • 80 posts
  • Local Club: no
Posted 09 May 2017 - 08:40 PM
Some nice details on this car :)
Not only did Contessa fit a 1275GT dashboard, they also fitted a under bonnet light - never seen that on a Wood & Pickett.
The sound insulation under the bonnet has a nice finish.
The rare details show just how original the car is = original Lucas battery connector, and rubber seals that match the interior, very rare.
Whats the thing in the corner of the battery box ?
A pleasure to follow the progress on this rare car.
Jens Christian
Edited by JC T ONE, 09 May 2017 - 08:49 PM.
#78 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 09 May 2017 - 09:07 PM
Jens Christian
Thanks for the comments nice to see that at least some share my views on this,
at the moment I am away from it, as for the thing in corner! investigating it seems
as though some sort of Battery securing device as to it bolted to side and along
underneath the Battery and although have seen the original type Battery connector
slaged of by some my experience back in the day was if you kept them clean and
smeared in vaseline they didn't give a lot of trouble.
The door seals coloured in the same as interior having some difficulty in sourcing
replacement but I will give it my best shot.
#79 Homersimpson
Homersimpson
  • 851 posts
Posted 09 May 2017 - 09:15 PM
Jens Christian
Hi, I'm not sure what colour door seals your looking for but Woolies do seals with a coloured edge if thats what they should be like?
http://www.woolies-t...side-seals.aspx
Hope this is of help.
#80 panky
panky
  • 1,852 posts
Posted 09 May 2017 - 09:37 PM
Cant believe how well preserved it is - a little gem :mrcool:
#81 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 10 May 2017 - 05:55 AM
Nice to see you cracking on again, this thing is such a nice bit of history, surely has to be a keeper when done. Some to look after and show off. Like the comment above I cant believe how well preserved this car is.
#82 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 16 June 2017 - 11:02 PM
Great to get back working on this, after a 5 wk break in Cyprus and a visit
to MCR day at Beaulieu, made a 2 day trip down to New Forest stayed in
Lyndhurst! rounded of our holiday nicely.
Thanks for all the comments!, I feel quite privileged to have found and bought
this car, and the fact that its well preserved!
First job was to temporary fit front bumper and grille, and fabricate a couple of
spot lamp brackets, have decided for the time being not to fit the Wolsley 2200
front grille that was previously fitted as the chrome work is badly pitted, and
would probably be hard to source another one, also found it difficult to get
spot lamp brackets it seem that most drill the bumper! but  want to be able
to put it back to original,
cleaned up the hubs a bit before stripping them of for cleaning and painting the
ball joints ect although showing no play will be stripped and checked at the same
time,
engine and gearbox although needing a good clean and paint not showing any
oil leaks apart from the usual gear shaft slightly,
rear subframe removed! and given a clean up ready for stripping, used a cold
water pressure cleaner, would have liked to done it with a steam cleaner but
that meant taking it of site,
subframe is in great condition for original!
condition of brake pipes under the Cadulac treatment is amazing for 40years old,
most parts that will be needed for rebuild are brake cylinders, handbrake cables
and quadrants Happy Days.
More to follow thanks for looking.
#83 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 17 June 2017 - 06:20 AM
Good to see you back on the rebuild. I can't believe how good the condition is, It shows the quality of the Cadulac treatment. When I first started off in the industry I was aware of Cadulac but like a lot of people at the time was very cynical regarding the claims made for it. Its certainly worked on yours.
#84 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 29 June 2017 - 10:03 PM
I used to do a lot of body repair work for a local BL dealer back in the 70s! he had a mobile
guy that rust treated the cars he sold, don't remember what he used , I thought it was Ziebart!
On my looking into the history of this car and Oyler Contessa car in general was speaking to
a friend of my Daughter in Law a couple of weeks ago! and she believes that her late Father
had one and that the car was previously owned by one of the Bradford group Smokie!
hopefully more info will turn up  :proud:
So on with the story, hopefully Photos will work,
stripped rear subframe, scraped all the Cadulac from accessible areas gave it a good going over
with wie wheel on grinder, then did the complete POR15 process on it decided that with the
amount Cadulac inside the seams ect that blasting would be counter productive, and it was
going to be re waxed,
original MOWOG stamp,
the boot floor and heel board were in great condition so cleaned up, the small bits of surface rust
were treated with Deox and given a coat of zinc primer,
then all the parts that the Cadulac was removed from were Stone Chiped primed flatted
back and the wheel housings painted in body colour! the boot floor and heel board were done in
Matblack, the areas that would be inaccessible the subframe was in place were given a
coat of under wax!
subframe was then refitted, would really  have liked to leave this of till all the painting was
don! but space for storage is at a premium, last job on the rear for the moment was to refit
the brake limiter valve and the original brake pipes with were in like new condition,
Engine crane being delivered on Friday so will get front end done next.
Thanks for looking! more to follow.
#85 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 01 July 2017 - 10:51 PM
Because of the ongoing crap with PB?????? whilst its still working for me,
got engine out this morning and removed front subframe,
requires a good clean up and a paint,
subframe the same rely only needs cleaning and paining,
bulkhead just a bit of surface rust where brake fluid has run down,
Thanks for looking! more to follow as long as my bucket keeps going O_O
although all my photos are backed up elsewhere, don't know whether its worth
using another hosting site as the same thing will probably happen there, IMOP
#86 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 02 July 2017 - 05:33 AM
Really great rebuild, try Imgur for picture hosting so much faster and easier look in the thread in Mini chat about photobucket problem.
#87 mab01uk
mab01uk
  • 13,074 posts
Posted 06 July 2017 - 11:00 PM
Good to see your Oyler Contessa restoration project is featured in the 'Coachbuilt Mini Register' section of the July 'CooperWorld' MCR magazine (page 49-50) and described by Steve Burkinshaw as the 'rarest of all coach built Minis'. :mrcool:
Edited by mab01uk, 06 July 2017 - 11:01 PM.
#88 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 07 July 2017 - 09:02 PM
Good to see it in CooperWorld! and Steve managed to come up with some info
that I didn't know, would you believe that I first got in touch with him just after I
bought it! still got there eventually, HaHa
Next update over the weekend whilst Potobucket still good for me, at the moment
reluctant to start trying somewhere else. :bah:
#89 panky
panky
  • 1,852 posts
Posted 07 July 2017 - 09:35 PM
All my links have gone today, it is only a matter of time before your do the same. Use Imgur, it's easier, quicker and very user friendly - and I'm an old fart ;D
#90 PNL629G
PNL629G
  • 48 posts
Posted 08 July 2017 - 10:06 AM
Love it. What an interesting Mini variant. Thanks for posting, really enjoyed reading it so far, and looking forward to the next updates! :)
    Bing (1)
