Coachbuilt Oyler Contessa (The Countess)
300 replies to this topic
#61 GT Jimmy
GT Jimmy
  • 1,646 posts
  • Local Club: S.U.N.M.C
Posted 16 April 2017 - 08:59 PM
Thanks. Forgot you'd be re installing the vinyl roof ha ha
#62 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 24 April 2017 - 09:38 PM
Once again thanks for the interest! bit late this week in updating, been up in
Scotland for a few days for Granddaughters 2nd birthday and family business
did manage to get some work done before the trip,
covered the body shell up and applied 3 coats of Lechlar Epoxy primer to bonnet and
boot lid.
After seeing a couple of other threads on here about rust under the bonnet frame and
other fitments decided that I better check it out,
I am quite confidant that due to the Cadulac rust proofing that was done and what I have found
else where that the inside of the main frame is in good condition, I will unpick the spot welds
on the buffer contact pads and bonnet stay bracket and attend to the small amount of
corrosion under them,
After a day and a half and sanding back the  Upol reface polyester spray filler, done with P180
on block dust free dry sanding a serious bit of work but very pleased with the results,
the remainder of the shell was given 3 coats of Lechlar epoxy primmer, then pushed
outside into sunshine, for the first time in a few months, took the opportunity to give
garage a cleanup and a bit of paint on walls.
Defiantly makes it a bit brighter! just deciding whether to get some LED tubes for the
lights! always used daylight tubes!!
All for now more to follow
#63 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 24 April 2017 - 10:16 PM
Very nice!
#64 jamesquintin
jamesquintin
  • 1,017 posts
Posted 25 April 2017 - 11:50 AM
Not sure if you've answered this before, but what Is your paint setup..? Compressor, guns, actual paint (2k,celley) ect?
#65 wingnut
wingnut
  • 464 posts
Posted 25 April 2017 - 02:54 PM
Great work
#66 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 25 April 2017 - 08:28 PM
Yeah, I am sure have been asked the same question before! painting is always an
issue, firstly after more or less 50yrs in the trade their is no way I would let anybody
else paint it for me, over the years have lost track of how many paint jobs I have done
on all sorts of vehicles, boats ect only thing haven't painted is aircraft.
On compressors have a 1000ltr belt drive 3hp any bigger needs 3phase so not an option
I have changed the built in water trap/regulator for a remote one with better fittings, hoses
ect for more air volume but it struggles with air fed mask O_O  for primer ect I use a Devilbus
gravity fed gun, for colour and clear a Devilbus  HVLP quite an old one had it for years!! but
with the price of a good spray gun what they are it will see me out HaHa,
over the years have used most types and makes of material when I started serving my
apprenticeship Celulose was the most used, never used for about 30yrs, have also used
fully Synthetic, ThermoPlastic Acrylic, both solvent and water base coats with single and
2pack clear.
On this job Lechlar 2 pack Epoxy primer (done) that will be dry sanded and then coated
with 2k primmer surfacer, flatted then finished with 2k solid colour, would have used clear
over base but there is no formulation available for the Damask Red, air dried in far from
ideal (miss my Lowbake Booth/oven) conditions.
I do know all the HSE +++++ regulations, and as it says on the can For Professional Use
Only ;D  Hope this helps and apologies for rambling on( probably an age thing)
#67 jamesquintin
jamesquintin
  • 1,017 posts
Posted 26 April 2017 - 01:18 PM
thanks for the info!
​Did you really mean 1,000ltrs..? I was thinking of getting this:
http://www.sgs-engin...sor-starter-kit
Am I stupid to even think about doing 2k at home? (I have a garage similar size to yours)
​ta!
#68 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 26 April 2017 - 04:19 PM
​ta!
Sorry did mean 100ltr bit of a typo there,
On using 2k at home thats your decision! as its dodgy kit.
#69 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 April 2017 - 04:58 PM
​ta!
I wouldn't even entertain it unless you have experience with it and know what you are doing.
You need to have precautions in place because if your neighbours have any issues with fumes and kick off, you will be in deep water.
#70 jamesquintin
jamesquintin
  • 1,017 posts
Posted 27 April 2017 - 08:53 AM
So what's the alternative..? Cellulose..? Can you get a good finish at home? Time isn't an issue
​Q
#71 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 27 April 2017 - 10:50 AM
​Q
I would say you can. I've recently painted mine in a similar sized garage and I used an Earlex Spray Station too.
Here's the post where the top coat was fresh: http://www.theminifo...empt/?p=3424414
Most important thing is to be safe. Cellulose is a lot more friendly for the home painter, but you still need a good mask.
spraybeater, really enjoying watching you work on this. I wish I was as skilled as you and could work as quickly!
#72 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 27 April 2017 - 05:12 PM
Hats of to you sir, this car is a one of a kind, and an amazing find.
I love the story that has gone with this car, and i truly love your work, you can tell you have done this for a while it looks awesome, this will be another stunner, and a magazine car thats for sure.
I couldn't help but notice the nice little work light under the bonnet, another really cool little touch done by the coach-builders.
#73 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 27 April 2017 - 08:37 PM
Oh hell! seem to have opened up a can of worms on this , on the using Cellulose,
yes you can make a really good job with it no problem, used it for about 20+ yrs
on everything from minis to Rolls Royces both solid colours and metalics in paint booths
and lock ups, but have you ever wondered why there are not so many small Body/Paint
shops about now? Cellulose is a Non compliant refinish material! along with solvent based
base coats and therefore (officially ) can't be used for painting cars younger than 40yrs old!
when you purchase these materials it usually says on the can for industrial use only,
and the powers that be are carrying it spot checks on paint stockists ,
it can be used on newer Motorcycles ,Tractors and some others, so small one man band
paint shops have all but disappeared, + high solvent paints are Highly inflammable I have
witnessed a fire in the extraction ducts of a paint shop,
So the powers that be require you to pay £1200++ to get a compliant Body Shop to paint
your car if it was registered after 1977 IMO. and as per TMF rules I am not suggesting or
advising anybody to do anything thats Dangerous or  Illegal
Deathrow
On the working quickly , I am retired But kind of treat it like going to work every day HaHaaaaaa
minimissions
Thanks for your interest yeh like the lamp under the bonnet as well only thing is the car has 4
of them fitted and it needs them all replaced at roughly £16 a pop.
by the way have answered your PM
#74 johnR
johnR
  • 2,302 posts
Posted 27 April 2017 - 09:40 PM
Always a worry when you find lots of working lights under the bonnet - suggests someone thinks you're going to be spending a lot of time under there at the roadside!! Fascinating build - can't wait to see it painted - and finished.
#75 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 27 April 2017 - 10:09 PM
A! no should have said their are 5 lamps in total 1 under bonnet,1 in  boot, i on dash , and 1 each side as
interior lights above B posts . 4 need replacing.
