Coachbuilt Oyler Contessa (The Countess)
300 replies to this topic
#31 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 11 March 2017 - 08:46 PM
Had a bit of luck! on the Saturday morning went passed the place where I get my gas supplies
and HeyHo they were open so managed to pickup a bottle, meant I could get started early on
the Monday morning.
So as the sill was ready for welding got carried away and had a bit of a welding spree,
DSC_0001_zpsvqw8xnlv.jpg[/URL
sill door step and Apex pane all fitted and ground back,
inner sill cleaned up and coated with epoxy primer,
a little skim of filler just to tidy up,
and coated with epoxy primer to keep it from forming surface rust, will be sanded back and redone when paint prep is
done,
The plan was to get wing to A panel de seamed join lead loaded as well this week but when I looked in the tinning paint
bottle it was past its sell by date ( remembered it was about 18yrs old last used on a Jaguar front wing nose cone)
[URL=http://s12.photobucket.com/user/frankhubbard2/media/Mini%20Contessa/DSC_0001_zpsdzocyydg.jpg.html]DSC_0001_zpsdzocyydg.jpg
So check out the bottom of door and was well pleased when I scraped back the wax coating and found the door was
in great condition!
Had another few photos to put up but having a nightmare with phtobucket tonight,
Thanks for looking .
#32 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 12 March 2017 - 08:29 PM
After having a nightmare with Photo bucket last night thought i would give it a go tonight with the
rest of update,
inner doorstep wasn't to bad just some pitting on sill flange, and a few pin holes, but just in between the
curved parts of A &  B posts I decided that buying 2 heritage doorsteps which include inner A post was
a bit pricey at £80. a piece as I would be cutting some of it of and not using !!!
managed to get 2 of these made up to the pattern of original , local sheet metal firm made them for a tenner
well pleased .
The only disappointment of the week was after trying locally to get solder paint for the lead loading
with out any luck phoned Frost restorations to find out there out of stock till the 17th March so kind of
slows up getting O/S panel work finished before starting N/S.
All for now, thanks for looking
#33 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 19 March 2017 - 09:37 PM
Now that my Rover Sprite Project is finished sold and gone to its new owner!
hopping to push this along in the next few weeks!
got all the welding done to the O/S just waiting for some fryolux to be delivered
to get the wing/a-panel join lead loaded was promised by Frost that it would be
in stock by the 17th but now they have put that back indefinitely so chased about
and found another supplier,
stripped the old paint back to bare metal as it had been painted a few times,
when cleaned the Cadulac treatment from rear wheel housing in really good condition,
third go with stripper on door,
Door refitted after cleaning up in checks and hinges and expoy priming-painting,
cleaned of some of the cadulac from the flitch panel it had gone quite brittle with
age but done its protection job well,
some damage found at door handle repaired and skimmed with a little filler,
back on its wheels ready for moving to get other side done,
how we used to fit door skins a bit of braze at the window frame these however are original ,
 when scrapping of Cadulac from wheel housing cleaned some from rear brake pipes and radius arm
these are all original , starting to feel a bit of a fraud on this one not taxing enoughHaHa,
as posted else where in the forum front page of the Super Cover book showing dates and dealer
details been doing a bit of research on the cars history .
Once again thanks for comments and views more to follow.
Edited by spraybeater, 19 March 2017 - 11:54 PM.
#34 GraemeC
GraemeC
  • 7,432 posts
Posted 20 March 2017 - 10:09 AM
So what's the sweeping line of colour change in the steel about?
#35 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 20 March 2017 - 11:03 AM
Yeah! wondered if someone would ask that , I believe its part of Phosphate dip
process done in the factory at the time, have seen on other BL cars of the
same era when I have bare metal repainted them back in the day.
Or maybe someone else has their own ideas
#36 GraemeC
GraemeC
  • 7,432 posts
Posted 20 March 2017 - 11:58 AM
Could be I guess - with no hole in the rear bulkhead this can't have gone through the Rotadip process that would've seen the whole shell submerged.
Maybe the later process just dipped the front and lower extremes on a conveyor.
#37 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 20 March 2017 - 10:49 PM
Great work =D, What paint stripper have you been using?
Thanks,
Mark.
#38 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 20 March 2017 - 11:19 PM
I don't who makes it! I got it from one of the local paint factors Northern Auto Paints,
just says Heavy duty paint stripper on the can was a bit pricey  but seems to do the job
stripped the bonnet today about 4 applications of stripper ( it was bl**dy thick paint +
some polyester spray filler ) certainly better than the modern watered down Nitromors
once I got through the crap celly top coats.
#39 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 21 March 2017 - 02:32 AM
Thanks for the info.
Mark.
#40 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 21 March 2017 - 09:18 AM
Thanks,
Mark.
Hope you don't mind me hijacking this thread. After reading through the reviews I decided (with a significant degree of cynicism) to try Screwfix's own brand paint stripper. Compared to Nitromors I can't believe how good it is. Just make sure you leave it on long enough. http://www.screwfix....per-500ml/17091
#41 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 21 March 2017 - 10:24 AM
Thanks,
Mark.
No problems, suppose being retired Motor Trade prefer using Motor Trade suppliers
find using local Srewfix a bit like going into McDonalds
#42 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 21 March 2017 - 10:47 AM
Thanks,
Mark.
I totally agree and normally wouldn't use Screwfix but having found Nitromors a complete waste of time I started looking at recommendations on the internet and was surprised when it came up on quite a few different forums therefore I decided to try it.
#43 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 27 March 2017 - 09:11 PM
As well as working on the bodywork of this been doing a bit of research into its life
story, once I get some word back from DVLA! will be trying to get in touch with the
previous owners, that is prior to the last one as he gave me what he had on it.
Anyway back to the bodywork,
this was the paint that was stripped from bonnet and scuttle had been pained a few times
so took a fair bit to remove,
some of what the paint was hiding ,
same as the dipping line on other side but appears that door must have been left open a bit
as 2 levels ,
fair bit of filler used by the coachbuilders when they deseamed it, don't particularly like deseamed
look but trying to keep it as original build sheet,
this was inside the overfills that the PO paid to have removed and treated before fitting +
he paid a fortune to have them fitted ( I have the receipt for the work) sometimes I despair of the
standards of some members of my old profession !!!!!!!
same can be said of BL this was inside the jacking point bare metal its kept not
to bad for 40yr old,
the rest of inner sill not to bad once cleaned up minimal panel replacement required,
Kenlowe fan fitted by coachbuilers at same time,
small repair needed to lower flitch, did break one of shocker bracket bolts! will get broken end
out the n subframe is removed,
door step and jacking point will be replaced they are not that bad have seen the day when
they would be cleaned up and reused,
ready for cleaning up and repairs getting done.
All for now more to follow next week!
#44 lawrence
lawrence
  • 1,339 posts
Posted 29 March 2017 - 10:17 PM
Are you not tempted to split the seams on the front panel to wing joint and perhaps shotblast them when they are open? I only ask as it would be a shame for rust to appear after all your hard work
Lawrence
#45 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 29 March 2017 - 11:12 PM
Lawrence
 Yeah! will be going back to these seams when the rest of the metal work is done,
they have been opened up both from inside and outside and old seam sealer removed
then treated with Deox gell, used to repair these seams for a local BL dealer back in the
day as they were always troublesome
Edited by spraybeater, 29 March 2017 - 11:14 PM.
    Bing (1)
