New Cooper S Engine Blocks?
26 replies to this topic
#16 Tupers
Tupers
  • 4,176 posts
Posted 23 January 2017 - 10:59 PM
I think that would be somewhere between £3500 & £6000 in todays money. I'm sure most of Swiftune and the likes customers would pay it.
I have always though it odd that they wouldn't do a pre A+ block without tappet chest covers. The AppK cars are allowed to run them due to the scarcity of S blocks and it would be a better block for general high performance applications.
#17 Cooperman
  • 23,569 posts
Posted 24 January 2017 - 10:25 AM
The Minis with the highest values are the original Cooper 'S' models. That is why the target is to produce a Mk.1 'S' block to encourage restorers to buy one. That way you could make a Mk.1 850 into a true replica 'S', or do a 'log-book' restoration to original specification and have a 'fully restored' Cooper 'S' worth, say, £30,000, which would make the cost of the block unimportant.
Are you sure A+ blocks are allowed in FIA historic racing? I thought it was only solid block A-series engines not the stronger A+ which is allowed, but I may be wrong.
It does seem likely that a figure of £5000 to £6000 will be the cost of a new 'S' block, but if you need one for competition then that won't be an issue.
#18 mab01uk
mab01uk
  • 13,084 posts
Posted 25 January 2017 - 08:26 PM
Minispares - "casting boxes made, samples have been cast, we are now just trying to get the machining done for an acceptable cost as the way we want it doing and the standard we are looking for is proving to be difficult and expensive."
http://mk1-forum.net...tart=10#p148602
#19 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 26 January 2017 - 08:15 AM
so do we have two separate projects on the go here or are minispares working with department 75?
#20 GraemeC
GraemeC
  • 7,475 posts
Posted 26 January 2017 - 09:15 AM
Separate projects
#21 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 27 January 2017 - 08:27 PM
Think the word is spreading there seams to be a few rarer blocks coming to the market from the hoarders
#22 Ivor Badger
Ivor Badger
  • 846 posts
Posted 27 January 2017 - 09:27 PM
The new block will probably be so expensive, that it will make little difference to the price of original blocks,
#23 mini-geek
mini-geek
  • 1,169 posts
Posted 27 January 2017 - 10:06 PM
People will still pay to have an original block to make their log book build
#24 Van13
Van13
  • 314 posts
Posted 29 January 2017 - 04:26 PM
mmm lets see
#25 benm
benm
  • 111 posts
Posted 30 January 2017 - 07:27 PM
As a machinist this is the case unfortunately, if machining an engine block from scratch was simple it'd be cheap and they would be available in abundance. you pay for quality when it comes to machining. also the investment in tooling and fixtures wouldn't be cheap either so thats factored in
#26 mab01uk
mab01uk
  • 13,084 posts
Posted 13 June 2017 - 06:46 PM
New Cooper S engine block is on its way........
Latest News update:-
"The finished item isn't going to be alloy, these were just cast to test the pattern boxes & start to work out the machining operations. The finished block will be cast iron just like the originals."
http://mk1-forum.net...=17995&start=10
#27 mab01uk
mab01uk
  • 13,084 posts
Posted 21 May 2021 - 05:30 PM
Minispares alloy block is now on their Instagram....
Video in link of Minispares new alloy 1275 'S' cylinder block running on one of Swiftune's engine dynos:-
https://www.instagra...g_web_copy_link
Screenshots from the video below
Edited by mab01uk, 21 May 2021 - 05:31 PM.
