How can I make sure the connectors stay on the battery even when tightened properly?
Battery Connector Jumps Off
Posted 18 January 2017 - 12:38 PM
Posted 18 January 2017 - 12:39 PM
Posted 18 January 2017 - 01:19 PM
Posted 18 January 2017 - 02:36 PM
Oval them a little, should stay on. Otherwise may have to get another terminal.
Posted 18 January 2017 - 03:47 PM
+ & - posts are actually different sizes.
Posted 18 January 2017 - 05:54 PM
my mini is a 1991 mayfair which has the clamp style one I stalled the car because i was getting used to the car when the connector jumped off the terminal and I had to drive back carefully for a spanner
Edited by Bradl, 18 January 2017 - 05:54 PM.
Posted 18 January 2017 - 06:42 PM
Posted 18 January 2017 - 08:15 PM
put a bit of shim around the terminal
Posted 18 January 2017 - 08:28 PM
Ben
Posted 19 January 2017 - 12:55 PM
If using the clamp type, please be sure to add an insulating cover on the positive terminal. The cardboard battery cover on its own does not give adequate safety considering that you may carry metal objects in the boot. We do not want to hear of Minis destroyed by electrical fires.
The taper angle of the truncated cone of the terminal is so small that a clamp terminal should never slip off if properly tightened. Small angle tapers are inherently self-locking as you will know from ball joint and track rod end maintenance.
Posted 19 January 2017 - 02:32 PM
If you are retaining the old screw down pot type then an old fixit used to be to use some cooking foil and fold into a strip and wrap around the battery post. That just makes up the gap and as long as you can still screw the pot into the top of the post then that should do it. As others have said, best to change to the side clamp type.
Posted 20 January 2017 - 12:45 AM
I strongly recommend following slidehammer 's advice above. The old pot type are basically useless, and a frequent cause of electrical problems.
Morse tapers on ball joints and track rod ends are under tension due to the nut tightened on the thread increasing the clamping force.
A battery clamp terminal can sprain and slowly become loose over time if overtightened or if the battery terminals are regularly disconnected and reconnected, you'll probably notice this more with classic cars as people tend to disconnect the batteries more often to store the vehicle over winter, it might be a case of replacing them for a new set, I bet they are the original items from new?
Sometimes the tapered battery terminals deform and crushed due to excessive clamping loads and a snug even fit to the terminal deteriorates, after all the terminal is soft due it being lead, I have known people to gently tap the lead terminal to slightly oval/deform it, if you loosen the battery clamp pinch bolt and open up the clearance gap, refit and pinch up the nut and bolt you should have a tight secure terminal.
If you have the screw down pot type then check it for wear and consider as previously mentioned.
Edited by neal, 20 January 2017 - 12:46 AM.
