My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#121 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 05 August 2017 - 02:18 PM
just a plug for an oilway.
does look odd though.
so I could just paint over it then?
#122 nicklouse
  • 18,523 posts
Posted 05 August 2017 - 02:20 PM
like i said it looks a bit odd. but if it is OK then yes but what is that "ring" around it they normally look neater.
#123 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 August 2017 - 03:04 PM
Don't know what that stuff round it is. Looks the same colour as the original paint. Sod it I'm just gonna paint it
#124 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 August 2017 - 03:06 PM
Any ideas what I'm making today?
Attached File  20170805_160208.jpg   68.01K   18 downloads
#125 panky
panky
  • 1,789 posts
Posted 05 August 2017 - 05:03 PM
Spare wheel carrier :D
#126 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 August 2017 - 05:12 PM
Yep
#127 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 06 August 2017 - 05:21 PM
Here's the finished item. I like using up bits knocking about the garage.Attached File  20170806_174851.jpg   46.16K   16 downloadsAttached File  20170806_174827.jpg   52.2K   17 downloads
I was going to make a frame to house a jerry can, but it's not a priority. Plus I need somewhere for the dogs to get in and out. Do need to get a rear number plate light on si I can get the loom sorted.
Edited by HUBBA.HUBBA, 06 August 2017 - 05:23 PM.
#128 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 August 2017 - 11:54 AM
Had another look at the tank today to take the sender out and test the resistance range so I know what gauges to get. Saying it was a right mess was an understatement. The bolts holding the sender in place were ok apart from one which snapped. I happen to have a spare 7 gallon tank so I think I'll cut out the flange off that and weld it to the new tanknd mount so i can use a standard but modified sender.Attached File  20170807_115218.jpg   105.52K   10 downloadsAttached File  20170807_115208.jpg   79.13K   9 downloadsAttached File  20170807_120640.jpg   74.75K   6 downloadsAttached File  20170807_120646.jpg   90.89K   2 downloads
#129 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 07 August 2017 - 12:53 PM
Looks bad for the age of car?
#130 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 August 2017 - 05:16 PM
I've emptied out the tank and there was rusty water in there too. Any ideas how to clean out a tank. Thinking of of just getting the karcher and just giving it a blast. Should get rid of any fuel vapours too ( as I'm welding! )
#131 nicklouse
  • 18,523 posts
Posted 07 August 2017 - 06:20 PM
should do it. you do have a fire extinguisher to hand. i would also get some of that tank sealant treatment that Frost were on about.
Or get a new alloy tank made up?
#132 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 August 2017 - 08:34 PM
What tank sealant treatment is this?
#133 nicklouse
  • 18,523 posts
Posted 07 August 2017 - 08:44 PM
two things they do.
http://www.frost.co....ir-my-fuel-tank
and
http://www.frost.co....air-sealer.html
used neither but have welded up a Seat ibiza MK1 tank.
#134 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 August 2017 - 02:40 PM
Been cleaning the inners of my block with a some compressed air and I'm sure something came flying out of this little hole. It looks very clean as if there was a ball bearing in it or something. Could anyone put my mind at rest.....is something supposed to be in there?
Attached File  20170810_153050.jpg   56.34K   6 downloadsAttached File  20170810_153059.jpg   54.93K   6 downloadsAttached File  20170810_153107.jpg   78.08K   4 downloads
#135 nicklouse
  • 18,523 posts
Posted 10 August 2017 - 02:50 PM
there is nothing that passes through the block and gearbox other than bolts and studs and Oil in the only point that has an O ring fitting.
no idea why there would be a hole there as it is too far in to come out anywhere for a fixing. but if there was a drilling there it may have had some crud old gasket in it.
