My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#91 nicklouse
  • 18,523 posts
Posted 24 July 2017 - 08:30 PM
How far is the fog light from the brake light? you may need to swap it out for another reversing light.
just checking the regs,
I'd say about 100mm. I do have a spare reverse lense that came with the light set if push comes to shove
(d) Minimum separation distance between a rear fog lamp and a stop lamp–
(i)In the case of a rear fog lamp which does not share a common lamp body with a stop lamp:
A distance of 100 mm between the light-emitting surfaces of the lamps when viewed in a direction parallel to the longitudinal axis of the vehicle
(ii)In the case of a rear fog lamp which shares a common lamp body with a stop lamp:
100 mm
http://www.legislati...chedule/11/made
Edited by nicklouse, 24 July 2017 - 08:34 PM.
#92 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 24 July 2017 - 08:44 PM
Umm. Just measured it and it 70mm between the lenses. I'll just have to see what happens on the day. If its an issue i'll do temp fix (did I say temporary? I mean permanent fix). They are pretty fexible at my mot garage. I have already pre cleared my 'competition only' tyres with them. I'll only be out on sunny days anyway.
Edited by HUBBA.HUBBA, 24 July 2017 - 08:49 PM.
#93 nicklouse
  • 18,523 posts
Posted 24 July 2017 - 08:48 PM
i would plan to have two rev lights and wire in a new FOG as it is not just an MOT issue but a road worthyness one.
#94 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 July 2017 - 04:47 PM
Had a word with mot man today and they'll be fine, but I have to get some crappy looking reflectors
#95 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 July 2017 - 08:12 PM
Ordered the tyre for the spare wheel and it arrived today. Ordered it from demon tweeks on monday, delivered to argos which is in my local Sainsburys and ready to pick up today. Got a few funny looks walking back past the tills.
Attached File  20170725_193740.jpg   70.45K   10 downloads
Got it put straight on the wheel. Really pleased with how it looks. Similar to my other tyres but smaller. As I see it its more of a space saver get me home type of spare.
I mounted a big one on the back but it was just too big.
Attached File  20170725_193758.jpg   74.08K   16 downloadsAttached File  20170725_193839.jpg   78.16K   12 downloads
Edited by HUBBA.HUBBA, 25 July 2017 - 08:35 PM.
#96 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 July 2017 - 08:25 PM
Turned my attention to the seats and the fact they are way too high. To a point where I can not get my legs under the steering wheel. Separated them from their subframe and then I had a urika moment
Attached File  20170725_202123.jpg   80.82K   9 downloadsAttached File  20170725_200643.jpg   60.79K   11 downloadsAttached File  20170725_200654.jpg   48.91K   6 downloads
Just turn the subframe upside down.
Attached File  20170725_200926.jpg   57.21K   6 downloads
Instantly lost 55mm Off the height. Sometimes it's just the simplest solutions are best. Still need to extend the steering wheel up a bit with a quick release.
Found this on the sub frame which is quite cool. A date marking the IVA test. Will leave that on.
Attached File  20170725_200736.jpg   61.43K   11 downloads
Edited by HUBBA.HUBBA, 25 July 2017 - 08:37 PM.
#97 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 July 2017 - 08:29 PM
Lastly today. Got my block,pistons, crank and bearings back from the machine shop today. Let the engine building commence! Glup!
Attached File  20170725_193723.jpg   61.8K   5 downloadsAttached File  20170725_193716.jpg   65.1K   6 downloads
Edited by HUBBA.HUBBA, 25 July 2017 - 08:30 PM.
#98 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 25 July 2017 - 09:04 PM
I have a 13x6 original weller spare for a Cub here. Never seen the rd.
If it's of interest please get in touch
Edited by minihobbymini, 25 July 2017 - 09:05 PM.
#99 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 July 2017 - 09:44 PM
Thanks but now I have just bought this tyre I'm a bit committed to it. What other bits do you have?
#100 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 25 July 2017 - 10:00 PM
That's it I'm afraid mate
#101 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 26 July 2017 - 06:15 PM
I've put the seats up for sale £100 for the pair with runners. In the for sale section.
Attached File  20170725_202123.jpg   80.82K   3 downloads
Edited by HUBBA.HUBBA, 27 July 2017 - 07:13 AM.
#102 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 26 July 2017 - 08:13 PM
Some stencils arrived today so I thought I'd have a little go. I must have been a bit drunk. At least I can give it a slight sand and try again. Will have to put a gap between the two words. Reads a bit weird at the moment.
Attached File  20170726_201001.jpg   19.23K   2 downloadsAttached File  20170726_202904.jpg   43.4K   10 downloadsAttached File  20170726_203200.jpg   62.45K   10 downloads
Edited by HUBBA.HUBBA, 26 July 2017 - 08:20 PM.
#103 Midas Mk1
Midas Mk1
  • 5,773 posts
  • Local Club: S.U.N.M.C
Posted 27 July 2017 - 07:29 AM
Sprayed on number plate would look ace like that, I know not legal, but hey ho  :whistling:
Liking the build alot!
#104 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 27 July 2017 - 08:32 AM
Just found some other bits.. pair of original front hi-lo suspension trumpets. Adjustable but also higher than originals.
#105 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 July 2017 - 12:57 PM
thanks, but got hi los on the front already. will be going to adjustable coil overs eventually in the future
