My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#901 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 17 December 2019 - 06:13 PM
Do it!!!
Twin supercharged?
Was thinking supercharged at the back and natural at the front giving it a 40fronf/60rear power distribution. Having an engine in the back would give it a bit more weight, so then I could really lighten my mini and then tow it to shows legally.
#902 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 December 2019 - 06:15 PM
Is there not a law against two engines running on separate gearboxes etc for a road going car
Bloody law makers. Have to investigate further.
#903 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 17 December 2019 - 07:30 PM
Cant see why it wouldn't be legal. Insurance could be an issue, and maybe MOT emmisions with this thing being quite new?
Supercharged rear, NA front sounds like a good idea yeah. Give the front wheels a break in corners ?
#904 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 17 December 2019 - 07:53 PM
Can't be any different legally to modern hybrids with an engine at the front and a motor at the back surely?
#905 Spider
  • 15,840 posts
Posted 18 December 2019 - 08:23 AM
Thinking of putting an engine in the back and make if 4wd. Am I mad? How hard can it be? Could pinch a few ideas from the gtm forum. Is there any reason why I can't have the gear selector rod coming out of the of the selector box and connecting to a gtm selector rod and have the normal one coming out the front?
Are you mad ? Well,,,,, it might sound a good idea but given it's largely not a reversible modification (as far as the body goes), I'd strong suggest you find one (Mini or Moke) to try first. Yes, it will have some added get up and go, but they are not as good as might first appear and certainly handling suffers in a big way - in part because of the added weight at the back and also in part because of the suspension set up and bump steer (which with some careful planing, can be largely dialed out).
A few people have modified the gearbox in the way you are thinking, though, you'll loose reverse gear you also need to fit an engine steady, that will couple both engines together as well as the gear shifter, otherwise, one engine will cause the other to slip out of gear quite often. You can't use the stock steady mount on the front engine though, or you'll soon tear it clean off.
#906 Ethel
  • 26,789 posts
Posted 18 December 2019 - 12:33 PM
That's my understanding too.
...photographic evidence on this forum in a leccy Mini conversion topic.
The whole regulatory system has moved on though. ABS & Airbags are a thing but we can't legally touch 'em as amateur builders.
It's all type approval and don't touch on new cars.
Pity because you could keep your engines in sync with electronics at least as reliably as mechanically nowadays.
#907 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 31 December 2019 - 04:08 PM
Had a word with my MOT chap yesterday and he had no problem with it. I have to officially have one engine to use only off road. So that'll be my long term plan.
#908 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 31 December 2019 - 04:10 PM
Started the motor up today and oil looks good. No mayo, Oil pressure ok. So fingers crossed.
#909 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 31 December 2019 - 04:15 PM
Did a bit on the roof today. It's about 20mm too narrow atm but I have some adjustments to make.Attached File  20191231_122946_resized.jpg   52.87K   0 downloads
Started the targa part first and will make the rest up to it.
Attached File  20191231_124841_resized.jpg   30.68K   1 downloadsAttached File  20191231_122954_resized.jpg   50.14K   4 downloadsAttached File  20191231_150302_resized.jpg   51.38K   4 downloadsAttached File  20191231_150311_resized.jpg   81.31K   3 downloadsAttached File  20191231_150328_resized.jpg   91.79K   2 downloads
#910 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,740 posts
  • Name: Chris
  • Local Club: None
Posted 31 December 2019 - 06:45 PM
Looking good, how is it going to be attached to the car?
#911 KTS
KTS
  • 2,490 posts
Posted 31 December 2019 - 09:11 PM
Looks good. are you going to leave the finish as is ?
#912 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 January 2020 - 10:56 AM
Was thinking thick velcro straps or exhaust u bolts
#913 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 January 2020 - 10:57 AM
Undecided really. Ths roof is a bit dented so just may leave it as it is.
#914 panky
panky
  • 1,850 posts
Posted 01 January 2020 - 11:07 AM
Or maybe some over-centre clips, nice and secure but easily removable
#915 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 January 2020 - 03:01 PM
What do they look like?
