My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#886 Spider
  • 14,782 posts
Posted 01 December 2019 - 06:17 PM
Chris
Something like this https://www.amazon.c...75222235&sr=8-2 ?
I'm unsure on that one, it seems an Oil for Petrol Engines, that might be useable in Diesel Engines.
Maybe this one (is a 10W40, but that's OK)
https://www.amazon.c...83&sr=8-1-fkmr3
I suggested a 10 litre pack as we do have them available here and they work out quite cheap, but this seems reasonable.
#887 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 01 December 2019 - 09:11 PM
15w40?
#888 Spider
  • 14,782 posts
Posted 01 December 2019 - 11:34 PM
15w40?
Sorry, that was what I meant to type!
Yeap, that'll be OK. Just run it long enough to get it warm and no more.
#889 nicklouse
  • 18,522 posts
Posted 01 December 2019 - 11:40 PM
On thing I will say the only time I have seen oil look that bad was when I had an oil leak into the water system on my T4.
my concern is just how much water got in there. And has any water been through the bearings before it emulsified.
#890 Ethel
  • 25,893 posts
Posted 02 December 2019 - 01:20 PM
How are other boosted engine done ?  I've not looked too closely at them.
I believe catch cans  are common. The Metro Turbo had a diverter valve on the bottom of the air filter & a non return valve in to the manifold brake servo take off.
I'm sure you could rig up something similar with cheapo Fleabay valves
#891 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 December 2019 - 01:39 PM
I'll just have to suck it and see. Will flush it a few times first and keep an eye on the oil pressure. Otherwise I'll start taking things apart.
#892 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 December 2019 - 05:59 PM
So far so good. After one oil and filter change the oil coming out is looking much better. I've put some more diesel oil in with some flush and started it up again and runs well again. Didn't have chance to drive it round the block, so will try it in the week. Oil pressure is good.
Edited by HUBBA.HUBBA, 08 December 2019 - 09:40 PM.
#893 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 December 2019 - 06:02 PM
One thing I have now noticed is with my nice shiny new dsn oil cap, when I screw down the rocker cover nuts the cap hits one of the rocker studs. Does anyone know where to get thicker rocker cover gaskets from.
#894 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 08 December 2019 - 09:15 PM
Do you mean the silicone rocker gaskets: http://www.minispare...|Back to search
#895 Spider
  • 14,782 posts
Posted 09 December 2019 - 04:14 AM
Good news - so far - on the oil situation.
You can try a silicon gasket like Tim has suggested or put 2 cork gaskets on.
#896 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 09 December 2019 - 09:10 AM
I tried the silicone gasket before, but couldn't get on with it. It expanded when hot and slipped out of position.
#897 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 December 2019 - 05:14 PM
Thinking of putting an engine in the back and make if 4wd. Am I mad? How hard can it be? Could pinch a few ideas from the gtm forum. Is there any reason why I can't have the gear selector rod coming out of the of the selector box and connecting to a gtm selector rod and have the normal one coming out the front?
Edited by HUBBA.HUBBA, 17 December 2019 - 05:15 PM.
#898 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 17 December 2019 - 05:20 PM
Do it!!!
Twin supercharged?
#899 nicklouse
  • 18,522 posts
Posted 17 December 2019 - 05:39 PM
None at all it is what Carl Austin did with his mad purple beast.
#900 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 17 December 2019 - 06:00 PM
Is there not a law against two engines running on separate gearboxes etc for a road going car
