My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#871 nicklouse
  • 18,522 posts
Posted 30 November 2019 - 02:24 PM
Oh dear me. Let me get this straight you are saying that the water got in while the rocker cover was off?
i would be pulling the engine.
#872 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 30 November 2019 - 02:39 PM
Yep water got in from above. Pull the engine and do what? Inspect what?
#873 nicklouse
  • 18,522 posts
Posted 30 November 2019 - 05:49 PM
bearings, journal, thrusts, cam followers everything. and hope you have not damaged the crank.
#874 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 30 November 2019 - 06:28 PM
I need to go and sit in a dark room somewhere.
#875 timmy850
timmy850
  • 3,290 posts
  • Local Club: MITG
Posted 30 November 2019 - 11:12 PM
I’d start by taking off the head and checking the head gasket. It might have leaked between the coolant and oil passages and not between the cylinders.
How long did it run with the milkshake in the engine? It should clear up pretty well after an oil change if it’s not adding more water in..
#876 Spider
  • 14,782 posts
Posted 30 November 2019 - 11:32 PM
How long did you run it for with the water in it ?
#877 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 December 2019 - 08:04 AM
Idled on the drive for 2 mins then drove round the block (2mins)
#878 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 December 2019 - 08:05 AM
engine ran for about 4 mins. Water definitely got on via the rockers
Edited by HUBBA.HUBBA, 01 December 2019 - 08:07 AM.
#879 Spider
  • 14,782 posts
Posted 01 December 2019 - 08:23 AM
You might be lucky.
Drain the Oil (which you have), then get some Diesel Engine Oil, may as well get 10 litres.
Change the Filter (which I know you have), fill as normal with the Diesel Oil, run it until normal operating temp, drive it gentle, but avoid loading it.
Dump the Oil, Change the Filter and repeat that above.
If in the second round, it comes out fairly clear, refill with your normal oil, change the filter go for a run, say 30 - 50 miles, again, avoid loading it, just drive 'normally'. Ideally, for this to have the best effect, you want to have the Crankcase Breathers set up as per factory, including a Vented Cap, even if temporarily.
I'm inclined to suggest a further Oil and Filter Change again at this point if everything seems and sounds normal.Then you should be right.
#880 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 December 2019 - 08:27 AM
You might be lucky.
OK, will give that a try. 2 things - Why diesel oil ? and could having milkshake make it run badly ( hunting around, poor ignition on a couple of cylinders, even though getting a good spark)?
Edited by HUBBA.HUBBA, 01 December 2019 - 08:38 AM.
#881 Spider
  • 14,782 posts
Posted 01 December 2019 - 09:10 AM
Diesel Engine Oil is very high in detergents.
While it will clean the inside of the engine, it;s not a good idea to use it for medium or long periods in our engines. It's low in ZDDP (usually) and in any case, the detergents in it are usually good enough to wash the ZDDP coating that you'd normally have built up on the Cam Followers.
Also, for this purpose, go for a lighter grade, a 10W30 or 10W40.
In regards to it's poor running - maybe. How is the crankcase breather hook up ?
#882 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 December 2019 - 11:28 AM
Breather from fuel pump cover, rocker cover and flywheel cover going into a vented catch can
#883 Spider
  • 14,782 posts
Posted 01 December 2019 - 05:17 PM
That won't work too well. You'll be getting mayo in the rocker cover for a long time to come.
It really needs to be via a PCV to the Inlet Manifold (maybe with a non-return valve?) or Air Inlet.
How are other boosted engine done ?  I've not looked too closely at them.
#884 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 December 2019 - 05:26 PM
Sorry, you know what, I'm talking rubbish. Forgot, the catcher vents to the intake for the supercharger now. Changed it 6 months ago!
Edited by HUBBA.HUBBA, 01 December 2019 - 05:27 PM.
#885 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 December 2019 - 06:09 PM
Chris
Something like this https://www.amazon.c...75222235&sr=8-2 ?
