My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#826 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 28 September 2019 - 05:35 PM
no 970, 997 or 1098's ?
It was getting a bit long, so just my favourites
Edited by HUBBA.HUBBA, 28 September 2019 - 05:35 PM.
#827 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 October 2019 - 11:41 AM
Not having much success crackle painting my rocker cover. Any tips or advice graciously received. Sprayed onto bare metal. Garage temp was 17 deg c. In the intstructions it says between 16-35 deg c. Don't know why its smooth on the side and glossy!
Attached File  20191010_123211_resized.jpg   115.43K   0 downloadsAttached File  20191010_123217_resized.jpg   105.23K   0 downloadsAttached File  20191010_123226_resized.jpg   98.85K   2 downloadsAttached File  20191010_123242_resized.jpg   31.23K   3 downloads
Edited by HUBBA.HUBBA, 10 October 2019 - 11:43 AM.
#828 nicklouse
  • 18,538 posts
Posted 10 October 2019 - 11:48 AM
you don't need high temp paint. I would say it is just poor paint.
#829 Spider
  • 14,796 posts
Posted 10 October 2019 - 04:23 PM
I find the VHT Brand good quality. I'd say the temp is too low and maybe the humidity too high. Only a guess.
Are you really sure you'd like a Black Crackle finish ? I know they look good, but keeping them looking that way and clean is next to impossible.
#830 KTS
KTS
  • 2,420 posts
Posted 10 October 2019 - 08:03 PM
i found it does need to go on quite thick - and baking in the oven really helps develop the crinkles (..it stinks though..)
#831 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 October 2019 - 08:16 PM
Need get the oven on when the wife is out all day.
#832 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 October 2019 - 08:17 PM
Don't mind not keeping it clean.
#833 timmy850
timmy850
  • 3,303 posts
  • Local Club: MITG
Posted 10 October 2019 - 11:21 PM
The other option is a heat gun or hair drier to get both the part and paint warm before painting. You do three coats at different angles and then warm it after, especially on the sections that haven’t crinkled yet.
#834 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 October 2019 - 07:42 AM
What, spray over the existing stuff?
#835 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 11 October 2019 - 08:10 AM
As said above, it needs more heat, spray over in one direction get the heat gun on it, another coat in the opposite direction and go over it with a heat gun, and then another coat diagonally and go over with the heat gun. you'll see it wrinkling up, but don't get it to hot or it will bubble. or if you have little oil heater cover it in foil so it doesn't get covered in paint put the rocker cover on and spray it on that, that's what I did with mine.
Don't put it in the oven, even if the wife is out. she'll be able to smell it for days afterwards, don't even take it in the house :lol:rot13nX.jpg
Edited by alex-95, 11 October 2019 - 08:13 AM.
#836 timmy850
timmy850
  • 3,303 posts
  • Local Club: MITG
Posted 11 October 2019 - 08:26 AM
You’ll probably have to strip it back and start again
Here’s a good guide, it shows the three angles to spray from when painting. Same as what’s written on the label
http://build-threads...-texture-paint/
#837 Steve220
Steve220
  • 5,038 posts
  • Local Club: BMC
Posted 11 October 2019 - 11:57 AM
You NEED a heat gun for this. I tried several times to use an oven or a hair drier. But the bullet and bought a cheap hot air gun, did heavy coats, dried each one with the gun.
#838 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 October 2019 - 01:40 PM
I'll give it a go with my paint stripper gun over the weekend. Cheers chaps
#839 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 October 2019 - 09:05 PM
Wow, what a difference an heater gun makes. Sorted.
Attached File  20191012_155255_resized.jpg   61.05K   2 downloadsAttached File  20191012_155303_resized.jpg   66.19K   3 downloadsAttached File  20191012_155309_resized.jpg   56.43K   2 downloads.
Thanks all
#840 Spider
  • 14,796 posts
Posted 13 October 2019 - 08:11 AM
Snap Crackle and Pop !
