My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#796 Spider
  • 15,104 posts
Posted 27 August 2019 - 07:27 PM
Out of interest would an M10 aluminium rivnut be Ok to earth battery cable?
The contact area between the Rivnut and metalwork it's fitted to is only small, so while it would work, you need to be mindful as to how much current you put through it and if a high current (ie, cranking), do so only for very short periods, allowing some time in between for the heat to dissipate.  Also, being Aluminium, if fitted to steel, there will in time be some corrosion here and it will end up a poor connection.
I feel a Bolt, Nut, Flat Washers and a 3 mm plate about 20 - 25 mm square would be a better way.
#797 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 29 August 2019 - 06:52 AM
https://store.thodio...mmo-can-speaker
Could do with a car stereo
#798 panky
panky
  • 1,792 posts
Posted 29 August 2019 - 08:53 AM
Wrong colour
#799 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 29 August 2019 - 09:01 AM
Pricey!
Could make one for a fraction of that.
#800 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 August 2019 - 12:44 PM
Wrong colour
I'd spray it
#801 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 August 2019 - 12:45 PM
Pricey!
Could, but weighing up the time and effort to make it. Could get one with a warranty
#802 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 August 2019 - 03:12 PM
Pricey!
Looking on Youtube. Didn't realise DIY bluetooth ammo speakers were a 'thing'. Might give it a go!
#803 Spider
  • 15,104 posts
Posted 29 August 2019 - 07:05 PM
Perfect for you and your Rat Machine :proud:
#804 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 29 August 2019 - 07:07 PM
Ammo box, couple of speakers and some sort of little Bluetooth amp, less than £100 easily! No point going mad for sound quality in a mini haha.
You can also hard wire it that way rather than relying on a battery.
#805 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 September 2019 - 09:09 PM
Earth point all done. Drilled through the chassis box section, sanded the surrounding area to bare metal and then m10 bolt through.
Attached File  20190831_100852_resized.jpg   74.13K   1 downloadsAttached File  20190831_100900_resized.jpg   45.82K   3 downloadsAttached File  20190831_101003_resized.jpg   32.97K   2 downloadsAttached File  20190831_102505_resized.jpg   46.48K   1 downloadsAttached File  20190831_143402_resized.jpg   69.23K   1 downloads
#806 l_jonez
l_jonez
  • 1,453 posts
Posted 03 September 2019 - 02:32 PM
Nice work as always, what's with the odd angle on the shock absorber?
#807 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 03 September 2019 - 06:25 PM
Think of might be the hydraulics at full height or the top mount is further back than a mini. Never really noticed it. I will be addressing that area at the top mount at some stage - a slight mod coming Soonish.
Edited by HUBBA.HUBBA, 03 September 2019 - 06:28 PM.
#808 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 16 September 2019 - 02:24 PM
First and last proper show I took the rat to. Had a great time , met shifty and crew for the first time. Looking forward to the next one.
Attached File  20190915_132509_resized.jpg   90.32K   0 downloads
Decided to do a half hearted entry to the 'most rusty' catagory. Think I'll get a loud horn and some bass bins for next time.
Attached File  20190915_132640_resized.jpg   59.95K   0 downloads
Edited by HUBBA.HUBBA, 16 September 2019 - 02:25 PM.
#809 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 September 2019 - 03:09 PM
Oh well, I can see all of these kits being hard mounted. Looks like the holes on the carb have been milled out a bit, to either take the flange welded to the charger or to take bigger bolts. Do you think I should get those gaskets with the o ring built in then?
Maybe ask about this with the guy who does the Superchargers?
A little update on the hard mounted Weber - Spoke to Stuart Gurr the other week and O rings or misab's are no good for this set up. Fuel pools in the recess. So not an option for me. Anyone want to buy a pair of misab plates and thackery washers  :D
#810 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,146 posts
  • Name: Sean
Posted 17 September 2019 - 08:29 PM
It was a pleasure to have you both on our stand!!
Look forward to seeing you again
