My New Amc Moke Project -Desert Rat Sleeper
#766
Posted 27 July 2019 - 04:36 PM
#767
Posted 27 July 2019 - 08:24 PM
Interesting selection of weapons !
Nice work, that should keep the sheep and dingoes out
#768
Posted 28 July 2019 - 04:51 PM
#769
Posted 02 August 2019 - 06:54 PM
Went for a spin tonight and I'm shaking. Wheel spinning in the dry, in second gear is a bit nuts.
Its amazing the difference in what ride height makes. Massive torque steer when at full height at the front. Definitely slamming it when on the road and raised to get over things.
Edited by HUBBA.HUBBA, 02 August 2019 - 06:55 PM.
#770
Posted 11 August 2019 - 03:46 PM
#771
Posted 11 August 2019 - 05:45 PM
Did not start well with the farmer changing things but I guess the organisers may not have been too good at the communication with them.
Many tents succumbed to the wind. It rained. There was great music and much cider consumed.
I cut it short as I needed a clean up before the 10 hour drive.
#772
Posted 11 August 2019 - 06:00 PM
Edited by HUBBA.HUBBA, 11 August 2019 - 06:04 PM.
#773
Posted 11 August 2019 - 06:02 PM
#774
Posted 11 August 2019 - 07:42 PM
#775
Posted 11 August 2019 - 11:26 PM
So what is the advance at idle with the vacuum advance disconnected? I can't see how it's adding that much advance at idle, they shouldn't add much more than 5-10 degrees depending on the unit? - does the vacuum unit have a number stamped on it?
#776
Posted 12 August 2019 - 06:58 AM
it's at 25 too. So vacuum advance dizzys have centrifugal advance springs in them or do they rely on vacuum aloneSo what is the advance at idle with the vacuum advance disconnected? I can't see how it's adding that much advance at idle, they shouldn't add much more than 5-10 degrees depending on the unit? - does the vacuum unit have a number stamped on it?
#777
Posted 12 August 2019 - 07:52 AM
How can you have 25 degrees at idle and at 4000rpm? Did you remove the mechanical advance?
#778
Posted 12 August 2019 - 08:42 AM
I just set the advance to 25 when reving to 4,000. It's a power spark electronic ingnition dizzy. With the vac pipe off it stays at 25 through out the rev range and as soon as its put back on it advances 10 deg (at idle). The positve boost pressure retaards it back down to 25 at high revs. But 35 deg at idle is a little high at bestThey have both mechanical and vacuum.
Edited by HUBBA.HUBBA, 12 August 2019 - 08:46 AM.
#779
Posted 12 August 2019 - 08:43 AM
#780
Posted 12 August 2019 - 08:47 AM
So what does it say on the Vac can?
Just had a look. Nothing on it externally
