My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#751 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 21 July 2019 - 08:04 AM
Found an issue with fuel or oil dripping from the bottom of my carb or charger onto a nice hot plate above the exhaust minfold, so decided to split the 2 and reseal.
Attached File  20190718_193035_resized.jpg   76.49K   0 downloadsAttached File  20190718_192949_resized.jpg   48.9K   0 downloadsAttached File  20190720_151105_resized.jpg   76.93K   0 downloads
Not great considering it's only done 50 miles.
#752 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 21 July 2019 - 08:07 AM
Did a little mod to the carb whilst I was at it. The plate holding the accelerator cable was starting to bend, so I bought a tiny m5 rose joint and using a spare couple of unused holes, I braced it. I would if anyone else with a vmax Weber kit has had the same issue.
Attached File  20190720_165100_resized.jpg   63.82K   0 downloads
Edited by HUBBA.HUBBA, 27 July 2019 - 04:16 PM.
#753 Spider
  • 14,821 posts
Posted 21 July 2019 - 09:38 AM
I'm far from having much experience with Webers (or similar) Carbs, but I was always of the impression that they shouldn't be hard mounted but soft mounted on O rings and Thackeray Washers ?
#754 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 21 July 2019 - 10:15 AM
My Dellorto has been hard mounted for the past 9 months and I've had no issues.
#755 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 21 July 2019 - 10:38 AM
Why's that? Are you referring to the way the carb is bolted to the charger?
Edited by HUBBA.HUBBA, 21 July 2019 - 10:45 AM.
#756 Spider
  • 14,821 posts
Posted 21 July 2019 - 10:48 AM
As I did mention, I didn't have a lot of experience with them, but all the side droughts I've seen fitted and not just on Minis, have been soft mounted and yes, the way the carb is hard bolted up to the Charger.
Here's Weber's advice;-
https://www.weberper..._Adjustment.pdf
#757 nicklouse
  • 18,562 posts
Posted 21 July 2019 - 02:00 PM
Side drafts should not be solid mounted.
#758 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 21 July 2019 - 04:31 PM
There's a layer of sikaflex inbetween the two. That might absorb abit of vibration, hopefully.
#759 nicklouse
  • 18,562 posts
Posted 21 July 2019 - 06:07 PM
Nope.
#760 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 21 July 2019 - 08:26 PM
Oh well, I can see all of these kits being hard mounted. Looks like the holes on the carb have been milled out a bit, to either take the flange welded to the charger or to take bigger bolts. Do you think I should get those gaskets with the o ring built in then?
Edited by HUBBA.HUBBA, 21 July 2019 - 08:41 PM.
#761 Spider
  • 14,821 posts
Posted 21 July 2019 - 08:43 PM
Maybe ask about this with the guy who does the Superchargers?
#762 nicklouse
  • 18,562 posts
Posted 21 July 2019 - 09:10 PM
The issue with the fuel is because of the vibrations shacking the fuel out of the float chamber.
But I am sure the developer has worked this out an knows what they are doing.
But this is what I had when I first fitted a sidedraught carb on a Mini.
#763 Spider
  • 14,821 posts
Posted 22 July 2019 - 05:14 AM
Now you mention this Nick, i recall my Brother had this issue. While he had the soft mount kit, he didn't realise the washers were a Thackeray Washer and how they worked. He did them up tight and the fuel would sometimes come out of the float chamber. Afte he was shown and backed them off, the issue went away.  Thinking back, this was a very long time ago - I was still in School !
#764 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 July 2019 - 04:04 PM
A bit of stretching today.Attached File  20190727_125333_resized.jpg   40.58K   0 downloads
Edited by HUBBA.HUBBA, 27 July 2019 - 04:05 PM.
#765 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 July 2019 - 04:14 PM
Much needed guttering on the bulk head. A bit of a design flaw on the Cub are the hinges for the bonnet. There is a rubber door seal on the bonnet which doesn't seal the hinges. Stretched some aluminium angle and bonded it on with sikaflex, put some D shaped seal along to create a channel.Attached File  20190727_133026_resized.jpg   62.61K   0 downloadsAttached File  20190727_133035_resized.jpg   46.65K   1 downloadsAttached File  20190727_133042_resized.jpg   37.1K   0 downloadsAttached File  20190727_133055_resized.jpg   66.48K   0 downloadsAttached File  20190727_134337_resized.jpg   75.33K   0 downloads
What ever it takes to hold it firm
Attached File  20190727_150316_resized.jpg   37.66K   0 downloads
