My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#736 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 12 July 2019 - 03:55 PM
Well that's a pain. Vacuum diaphragm is being blocked by the oil pipe, even if I move the leads round, its just on the point of where it needs to be. I can't believe the cost of the replacement braided hose.
Attached File  dizzy oil pipe.jpg   59.64K   1 downloads
For near enough the price of a new oil pick up pipe, I could have a 13 core oil cooler and hoses for and just an extra £15. I'm tempted. How things escalate!
Edited by HUBBA.HUBBA, 12 July 2019 - 06:07 PM.
#737 Spider
  • 15,108 posts
Posted 12 July 2019 - 07:07 PM
I can't say I've ever been crazy about any braided hose here, eventually, I've found, they all leak or weep. Oil Coolers are just as bad.
Have you tried rotating the distributor drive on tooth each way ? That might put the Vacuum Advance Can in a better location.
#738 nicklouse
  • 18,689 posts
Posted 13 July 2019 - 12:05 AM
Just twiddle the drive position so it is better.
Also cheap.
#739 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 July 2019 - 07:34 AM
Of course! I'm a silly sod. Thank God I didn't order anything. Cheers chaps
#740 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 July 2019 - 02:25 PM
Sorted! 25 degrees ar 4000rpm. Afr 12:1. Just need to go for a spin tomorrow and test it under load. Advance readings staying nice and stable. One thing I did notice was the strobe not picking up much signal until its revving (both new and old strobes). The spark on the plugs is much stronger than before.
Attached File  20190713_131514_resized.jpg   30.94K   1 downloads
Edited by HUBBA.HUBBA, 13 July 2019 - 02:26 PM.
#741 Spider
  • 15,108 posts
Posted 13 July 2019 - 05:59 PM
Nice work mate ;D
If you are wanting to get the strobe to work at very low revs, try opening the plug gaps up but then resent them after sorting the timing.
No guarantee this will work, but sometimes it does.
#742 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 July 2019 - 06:31 PM
Does anyone know where i can get ducting from like the standard oem air ducting. I need 70mm ID flexible ducting (the ribbed nylon thick plastic type, not the thin spiral type.
#743 Ethel
  • 26,061 posts
Posted 14 July 2019 - 11:39 PM
Looks promising
#744 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 15 July 2019 - 02:02 AM
I bought some from ramair, they have different diameter pipes
#745 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 July 2019 - 06:49 AM
Looks promising
Thanks, but that's the thin spiral type. It splits when you tighten the jubilee clip
#746 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 July 2019 - 07:11 AM
Looking for something more like this. Having a split is a bonus. I need it to cover a fibre glass repair on my air intake precleaner pipe. It snapped off the other week whilst on the trailer. Luckily it landed inside the car.
Attached File  Screenshot_20190715-075109_Chrome.jpg   31.37K   1 downloadsAttached File  20190715_080127_resized.jpg   63.75K   1 downloads
Attached File  20190715_082545_resized.jpg   27.42K   1 downloads
Edited by HUBBA.HUBBA, 15 July 2019 - 07:35 AM.
#747 Ethel
  • 26,061 posts
Posted 15 July 2019 - 09:23 AM
But isn't that rat look  O_O  It'd sand down.
Mesh sleeve?  used on scuba cylinders etc.
#748 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 July 2019 - 12:19 PM
Ha, I was thinking it was a bit ratty. I've come up with another idea, going to rap it in rope.
#749 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 July 2019 - 03:57 PM
A bit ropey but hey
A ropey but hey
Attached File  a bit ropey.jpg   35.79K   0 downloads
Edited by HUBBA.HUBBA, 18 July 2019 - 05:57 AM.
#750 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 July 2019 - 04:08 PM
Set up my timing etc and whilst it ticks over fine as soon a I boot it, the mixture goes off the scale (too rich). Had a word with Stuart G and I suggested may be the jets are too much, which he agreed. Then it dawned on me it could be poor air flow, I had messed about putting my cold air induction on. In doing so i used 2 trimmed down Pipercross sock filters on and squeezed them into the K&N shaped box.I opened the box up, put the original Ramair filter on and it runs fine!
Now need to increase the size of the filter box to get good airflow round the filter so I can seal it up again.
Attached File  cold air induction.jpg   50.68K   0 downloads
