My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#691 nicklouse
  • 18,562 posts
Posted 17 June 2019 - 01:39 PM
That's a hardy biscuit, took a right dunking
What drill bit should you use for a Hobnob - masonry?
one of those universal jobbies should do.
#692 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 17 June 2019 - 05:32 PM
The King of dunking. The SAS of biscuits
#693 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 June 2019 - 05:33 PM
For Metal drill bit
#694 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 June 2019 - 06:15 PM
Hydraulic line guards drain holes drilled and mounted in.
Attached File  20190617_190525_resized.jpg   37.74K   0 downloadsAttached File  20190617_190546_resized.jpg   39.93K   0 downloads
Edited by HUBBA.HUBBA, 17 June 2019 - 06:16 PM.
#695 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 17 June 2019 - 06:20 PM
Decided to block off the top vent. 1 to stop rain getting in and 2 so that the air flow is in low at the front, then up and out of the vents at the rear. To shift the heat away.
Attached File  20190617_171618_resized.jpg   63.52K   0 downloads
Might keep it silver.
Edited by HUBBA.HUBBA, 17 June 2019 - 06:21 PM.
#696 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 20 June 2019 - 08:41 PM
One thing I noticed a couple of days ago is that the rear wheels stick out more than the fronts.
Attached File  20190620_185826_resized.jpg   34.43K   1 downloads
Some 1inch spacers arrived today form minispares. Hopefully they will address a little inner arch tyre rub.
Attached File  20190620_185842_resized.jpg   33.58K   1 downloads
One down, one to go.
#697 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 22 June 2019 - 09:41 AM
Pressed my brake pedal yesterday and it went straight to the floor! found a nice brake fluid puddle on the floor of the garage. I had tightened the fitting going to the front /rear part of the regulator as I had seen a weep. It seems that it was threaded, doh! Tightening it just made it worse.
Attached File  moke brake regulator.jpg   43.63K   0 downloadsAttached File  moke brake union.jpg   35.43K   0 downloads
I got my scope to look at the thread on the regulator and it looks ok I think. I'm hoping the brass fitting thread will give up before the steel in the regulator
I really could do with putting a new line on this weekend but minispares oldbury isn't open on Saturdays now!! right pain.
Can anyone tell me which end on the line is metric and which is imperial?
#698 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 22 June 2019 - 09:49 AM
Changed the bottom shock bolts for competition ones as one was bent. One was a right pain,but with a hacksaw, penetrating fluid, drift, MAP gas and impact gun - it lost.
Attached File  moke bottom bolt.jpg   32.37K   0 downloadsAttached File  moke bottom bolts.jpg   24.34K   0 downloads
Attached File  moke suspension bolt fitted.jpg   63.97K   0 downloads
#699 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 22 June 2019 - 09:57 AM
Both sides done, with the spacers. One thing i have always come across are the splines on new wheel studs being course and the original ones being fine, which doesn't really help fitting. Nothing a big hammer can't sort out. Excuse the picture quality.
Attached File  moke studs.jpg   23.16K   0 downloads
Now the fat spacers on.
Attached File  moke hub.jpg   26.82K   0 downloadsAttached File  moke spacer.jpg   29.61K   0 downloads
#700 Spider
  • 14,824 posts
Posted 22 June 2019 - 08:08 PM
Bummer ! But glad you found this the way you did.
The Threads in those 'regulators' are M10 x 1.0.  I'd say that the fitting on your Brake Line was 3/8" UNF.
I've tried the brass fittings a while back and I gotta say, I'm not crazy about them at all.
#701 Spider
  • 14,824 posts
Posted 22 June 2019 - 08:12 PM
We swap out the original 3/8" Shock Bolts - Front and Rear - to 1/2".
The 3/8" don't last too long at all !
I have noticed many replacement wheel studs have a courser and 'taller' splining on them, I suspect they do this in case the original splining in the flange is stripped.
#702 nicklouse
  • 18,562 posts
Posted 22 June 2019 - 08:52 PM
KAD do new rear axles with 1/2" fittings. or cut the onld off and drill and tap to 1/2"
i want to do a rear ARB bracket that also puts the 3/8"in double sheer. that should be fine.
#703 nicklouse
  • 18,562 posts
Posted 22 June 2019 - 08:53 PM
mmmm studs
#704 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 22 June 2019 - 10:26 PM
.... I had tightened the fitting going to the front /rear part of the regulator as I had seen a weep. It seems that it was threaded, doh! Tightening it just made it worse.
....Can anyone tell me which end on the line is metric and which is imperial?
FAM7821 brake valve requires SAE metric thread connectors.
Metric thread connectors normally have a nick on the hex
https://www.ebay.co....wMAAOSwaLhZg254
Can you guess what you've done wrong yet :P
(it's an easy mistake to make, you should see some of the muck-ups i've done in the past :shy:)
#705 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 June 2019 - 03:33 PM
I've just had a look at both ends and neither have a 'nick'.I did dry test them before assembly. Must have cross threaded it on final assembly.
Edited by HUBBA.HUBBA, 23 June 2019 - 04:05 PM.
