My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#676 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 27 May 2019 - 01:16 PM
MiniSport do Bilstein B6 and B4
looked at those but they don't provide the facts and figures. Need to know the lengths
#677 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 31 May 2019 - 01:07 PM
Is it worth getting in touch with Protech and seeing if they can do you a custom set?
#678 Spider
  • 15,850 posts
Posted 11 June 2019 - 07:02 AM
One thing I don't get, when companies quote the open and closed lengths, they say from pin centres. But there is no pin centre on the top of the rear shock, So where do they measure it from? The point where the shock passed through the bodywork to the bottom pin centre (in between the 2 rubbers)?
Different manufacturers measure from different points, when Studs (or Pins) are involved..
Some measure from between the two rubbers and some measure from the top of the Shock Body.
The Dimensions I quoted earlier are from between the Two Rubbers with the Nut done up to the Shoulder on the Stud.
#679 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 June 2019 - 06:49 PM
I've ordered the adjustable spax from mini spares. Open to 410mm with about 140mm stroke.
#680 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 June 2019 - 08:56 PM
Got all my extended suspension nuckles on and they work! Need to put a couple of washers (shims( on the rear off side as it is a little lower than the rest. Here's a couple of pictures to show how I made them.
Attached File  20190608_145458.jpg   59.08K   4 downloadsAttached File  20190608_145433.jpg   55.53K   4 downloads
This is how I made the extension pieces and collars. Using two steel bars. 1/2 inch and 19mm. Drilled the 19mm to match the diameter of the original nuckle.
Attached File  20190612_221738.jpg   53.66K   3 downloads
Edited by HUBBA.HUBBA, 12 June 2019 - 09:21 PM.
#681 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 June 2019 - 09:02 PM
Spax (rear) arrived today, fair play to minispares and Simon. Got them out quickly to me. Bit of a size difference to the old standard ones.Attached File  20190612_140927_resized.jpg   56.76K   0 downloads
#682 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 June 2019 - 09:11 PM
Had a spare 1/2hr yesterday and decided to sort something that had been bugging me for ages but never got round to sorting. The events on the bonnet, with the screen down the engine bay was exposing my face to an untested engine. So cut the round holes into slots and riveted some mesh on.
Attached File  20190612_220525.jpg   56.86K   1 downloads
Edited by HUBBA.HUBBA, 16 June 2019 - 02:21 PM.
#683 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 16 June 2019 - 02:21 PM
You've seen the turbo red mini making a cuppa tea. Well, I always need a biscuit with mine!
The suspension is a bit bouncy as I haven't put the rear shocks on yet.
#684 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 16 June 2019 - 05:59 PM
Didn't see this till today.
Couldn't you have bought some Austin Metro ones? 5 minutes machining & they would have been done.
#685 Spider
  • 15,850 posts
Posted 16 June 2019 - 08:05 PM
Nice work on the knuckles all the same, it seems they have done the trick.
There's a HUGE difference in the shocker lengths and they seem to have been done pretty quick.
The speed with which you're able to dunk a biscuit is impressive, almost to the point where this could be made in to an active suspension system !
#686 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 16 June 2019 - 08:15 PM
Here's a piccy of how high the suspension can go with out the shocks on.
Attached File  20190616_163754_resized.jpg   33.2K   0 downloads
#687 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 16 June 2019 - 08:19 PM
The off side rear was a bit lower, so 3 washers packed the nuckles to the correct height.
Attached File  20190616_164625_resized.jpg   34.45K   0 downloads
Edited by HUBBA.HUBBA, 16 June 2019 - 08:19 PM.
#688 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 16 June 2019 - 08:23 PM
Started on the guards for the hydraulic lines running under the sills.Attached File  20190616_190746_resized.jpg   35K   0 downloads
#689 l_jonez
l_jonez
  • 1,453 posts
Posted 16 June 2019 - 09:41 PM
That's a hardy biscuit, took a right dunking
#690 Ethel
  • 26,795 posts
Posted 17 June 2019 - 10:06 AM
What drill bit should you use for a Hobnob - masonry?
