My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#46 nicklouse
  • 19,058 posts
Posted 19 June 2017 - 03:20 PM
Just in case people don't know what I'm on about. Here's some pics
attachicon.gif20170619_124545.jpgattachicon.gif20170619_124601.jpgattachicon.gif20170619_124616.jpg
There's a bit if angle iron welded on as a bracket with holes in already. May be the newer amc cub had 2 pairs of quadrants
I would say that a second set of quadrants would fit just nicely in them there holes. should work better as well.
#47 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 19 June 2017 - 07:58 PM
Just in case people don't know what I'm on about. Here's some picsattachicon.gif20170619_124545.jpgattachicon.gif20170619_124601.jpgattachicon.gif20170619_124616.jpg
Minihobbymini has a set for a cub he is good enought to send me.
#48 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 19 June 2017 - 08:19 PM
Was let loose with a can of paint earlier. Though I try a few bits and bobs and panels
Attached File  20170619_200529.jpg   67.92K   12 downloads
Attached File  20170619_201918.jpg   36.77K   9 downloads
Also gave the bonnet a hair cut
Attached File  20170619_200616.jpg   63.14K   16 downloads
Started to mount the wiper mechanism in and realised there wasn't enough room to mount it using the strap in the normal way. So now I have to make a bracket to hold it place.
Attached File  20170619_201546.jpg   78.33K   6 downloadsAttached File  20170619_201625.jpg   73K   6 downloadsAttached File  20170619_201706.jpg   58.67K   8 downloads
#49 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 22 June 2017 - 07:41 AM
Wasn't sure about the bonnet hump ( still not 100%) but with it sprayed up, it makes it look better. If I decide against it at a later date I'll just put the black slats directly on the bonnet.
Attached File  20170622_083638.jpg   75.94K   27 downloads
Edited by HUBBA.HUBBA, 22 June 2017 - 07:42 AM.
#50 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 June 2017 - 07:10 AM
These arrived the other day from Bullmotif. Excellent service from them as usual. In a bit of a quandary, seems a shame to spray the nice shiny new chrome bits. Might just vinyl wrap them and then spray.
Attached File  20170625_080518.jpg   51.37K   5 downloads
#51 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 June 2017 - 06:06 PM
My mate cubbacub came round today to get some welding done for the MOT. Took the opportunity to do a comparison piccy.
Attached File  20170625_143127.jpg   93.5K   41 downloads
Mine is definitely going to look like a moke on steroids.
Attached File  20170625_143117.jpg   101.73K   51 downloads
Edited by HUBBA.HUBBA, 25 June 2017 - 06:07 PM.
#52 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 July 2017 - 05:49 PM
Welded up the wiper motor brackets
Attached File  20170702_155824.jpg   78.64K   13 downloads
And now I have a wiper mechanism that folds with the screen
Attached File  20170702_155846.jpg   67.08K   10 downloads
Also weldeed in the captive nuts that house the stainless steel 8mm grub screws that will hold the screen frame secure.
Attached File  20170702_155902.jpg   64.13K   6 downloadsAttached File  20170702_155923.jpg   56.77K   9 downloads
Edited by HUBBA.HUBBA, 10 July 2017 - 10:03 PM.
#53 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 04 July 2017 - 04:41 PM
Managed to weld my big nuts!Attached File  20170704_164409.jpg   56.64K   17 downloads
#54 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 04 July 2017 - 04:43 PM
Got one of my slightly over engineered windscreen supports on. One down one to go
Attached File  20170704_170757.jpg   52.68K   31 downloadsAttached File  20170704_170805.jpg   42.05K   16 downloads
Edited by HUBBA.HUBBA, 04 July 2017 - 08:54 PM.
#55 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 July 2017 - 06:24 PM
I have Brakes! There seams to be abit of pedal travel, could this be because I haven't adjusted the rear drums /shoes yet? I don't need to pump them. There just seems abit more travel than normal.
And why is it that every time I bleed brakes I knock over my jam jar full of spent fluid and flick fluid everywhere with the pipe when taking it off the bleed screw! doh
Edited by HUBBA.HUBBA, 14 July 2017 - 07:30 PM.
#56 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 July 2017 - 07:25 PM
I've always ended up putting neg camber on every mini I have owned so why break a habit?
So fitted 1.5 neg cam arms and adjustable heavy duty tiebars. Definately gives him a better stance ( not that you can see it in the pic)
Attached File  20170713_123617.jpg   56.08K   4 downloadsAttached File  20170713_145806.jpg   63.2K   1 downloadsAttached File  20170713_145722.jpg   62.37K   5 downloads
Finished off the screen support for the other side and sprayed abit more wing
Attached File  20170713_145818-1.jpg   42.79K   7 downloads
New front indicator/side lights sprayed up. Did try to wrap the chrome and then spray but it looked crap so bit the bullet and sanded the chrome and sprayed.
Attached File  20170713_145812.jpg   33.57K   5 downloads
and finally cut a section out of the dash as I want to make the drivers side into more of a pod for the gauges
Attached File  20170713_145829.jpg   80.61K   13 downloads
#57 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 14 July 2017 - 08:55 PM
Also, rubber bonnet catches
Attached File  20170713_145730-1.jpg   57.28K   6 downloads
#58 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 July 2017 - 12:40 PM
got my new adjustable arm wipers trimmed and fitted for the cropped screen. they look very sweet. got them from Car Builder Solutions whom I have found provide excellent service and extended screen washer jet.
Attached File  20170715_111914.jpg   52.98K   6 downloads
#59 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 July 2017 - 12:42 PM
This is where my screen supports sleep when not in use.
Attached File  20170715_111115.jpg   36.94K   11 downloads
#60 pdaykin
pdaykin
  • 587 posts
Posted 16 July 2017 - 06:52 AM
I love these 'unusual' builds. How do you find the time ?
