My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#541 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 28 October 2018 - 08:28 PM
re the fuel cap i would have left it on and made sure there was a metal sheet over it. hot rocks will go through just about anything.
Sorry misdescibed. Put the fuel cap over the 2 sheets of plastic and then taped over the lot. Have left it on as I will tack a couple of welds on for the rear support bars. I'll put a piece of metal over the top.?
Edited by HUBBA.HUBBA, 28 October 2018 - 08:31 PM.
#542 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 04 November 2018 - 07:55 PM
Worked on the cage today.Attached File  20181103_142214_resized.jpg   23.37K   1 downloads softened up the corners of the plates a bit. They were a bit sharp looking.
Attached File  20181103_142225_resized.jpg   19.91K   2 downloadsAttached File  20181103_142229_resized.jpg   33.05K   0 downloadsAttached File  20181103_170235_resized.jpg   28.15K   0 downloads Bolted them in.
Attached File  20181103_142240_resized.jpg   71.63K   1 downloadsAttached File  20181103_143103_resized.jpg   68.21K   0 downloadsAttached File  20181103_142732_resized.jpg   36.69K   0 downloads decided to hole drill the ends in order to create a curve to fit round the tubing it's going to be welded to. First drill didn't have enough umph. Had to use my work Milwaukee, which makes all other drills feel like toys.
Attached File  20181103_143108_resized.jpg   50.26K   0 downloads
Even that found it hard work. Used the angle grinder in the end!
Clamped the front hoop to the windscreen frame to keep it inline
Attached File  20181104_134540_resized.jpg   38.76K   0 downloadsAttached File  20181104_134603_resized.jpg   72.13K   0 downloads
The welding blanket worked a treat.
Attached File  20181104_160718_resized.jpg   89.34K   1 downloadsAttached File  20181104_160726_resized.jpg   69.4K   0 downloads
Typical. Welds get better at the end of the job.
Attached File  20181104_160602_resized.jpg   43.45K   2 downloads
And finally, my first ever designed and made roll cage build. As it not for any competion use or any thing like that, I'll be tidying up the welds.
Attached File  20181104_160837_resized.jpg   81.26K   2 downloads
#543 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 November 2018 - 10:26 PM
All sprayed upAttached File  20181107_143414_resized.jpg   87.55K   3 downloads
And in! Will take a better side piccy when possible.
Attached File  20181107_150935_resized.jpg   70.85K   4 downloads
#544 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 09 November 2018 - 06:41 AM
This thing gets better each time I read the thread, keep it up!!
#545 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 November 2018 - 12:42 PM
Here's side view of the cage. I'm really pleased how its turned out.
Attached File  20181110_112339_resized.jpg   103.89K   8 downloads
now need to sort a hood
Attached File  20181110_112241_resized.jpg   101.33K   8 downloads
Got a sample but it seems a bit thin compared to the existing black one.
Attached File  20181110_122447_resized.jpg   30.61K   2 downloads
Can't seem to find a car hood canvass supplier. was thinking of making the hood myself. How hard can it be? bit of cloth, sewing machine and thread!
Attached File  20181110_112411_resized.jpg   94.09K   3 downloads
I'm having to do all of this - the cage, hood etc so it can live outside under this new purchase (its a bit high so will have to modify it)
I really need to work on the mini
#546 panky
panky
  • 1,790 posts
Posted 10 November 2018 - 02:56 PM
Cage looks great. A bit of advice with the Trike Home is to leave the ventilation flaps open all the time, it does cut down with condensation.
#547 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 November 2018 - 03:04 PM
Cheers. I might try and made something to hold the vents open without rolling them up so rain cant get in.
#548 panky
panky
  • 1,790 posts
Posted 10 November 2018 - 03:06 PM
The mesh seems to keep the rain out OK even when it's windy.
#549 nicklouse
  • 18,564 posts
Posted 10 November 2018 - 04:34 PM
just a point about the cage bolts above your head. it is always goob practice to have the heads on the inside and the pointy ends that stick out of the nuts being away from your head. or to trim the bolts down so as to be just about flush which ever wy you fit them so as to not cut the cover.
it does look like you will be a long way from then but it is amasing how much the body and the belts streach in a crash.
#550 timmy850
timmy850
  • 3,319 posts
  • Local Club: MITG
Posted 10 November 2018 - 09:05 PM
Perhaps a minimal roof like you can get for a MX5?
https://rev9autospor...bikini-top.html
#551 vx220
vx220
  • 419 posts
Posted 11 November 2018 - 09:35 AM
Love this build, could be worth posting a link or pics to this thread?
http://forum.retro-r...repurposed-pics
Starts off owner-jeep related, but halfway through the first page someone asks what the UK equivalent would be...
#552 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 November 2018 - 11:18 AM
Was thinking of putting padding on to be honest
#553 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 November 2018 - 11:21 AM
Was thinking of a bikini top type of thing with a centre section at the rear with a window the zips out making it into a bikini (if that makes sense)
#554 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 November 2018 - 11:43 AM
Just registered. No option to put pictures up though.
#555 nicklouse
  • 18,564 posts
Posted 11 November 2018 - 12:41 PM
that as well.
