My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#526 GraemeC
GraemeC
  • 7,437 posts
Posted 07 October 2018 - 07:57 AM
Obviously for it ro leak there the water must be tracking from somewhere else as there are no water jacket ports at that point.
I run the engine dry until the head is warm to the touch, then cheque torque and fill with coolant.
I would also check your torque wrench is reasonably accurate.
#527 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 07 October 2018 - 08:17 AM
funny you say that about the torque wrench had a look last night for places to get it calibrated. I have drained the water, do you think it is worth doing that warm up process now it has leaked?
#528 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 October 2018 - 09:39 AM
I wondered of these gauge type ones were accurate. To use as a comparison.Attached File  s-l400-1.jpg   12.04K   0 downloads
#529 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 October 2018 - 12:38 PM
Well, good news. Went to a car accessories shop (Autac) by me and tested the wrench and its bob on. Bob (owner) also said to warm up without water, turn off, undo nuts, retorque nuts whilst still warm and fill up....it worked?. Cheers GraemeAttached File  20181007_123447_resized.jpg   80.1K   3 downloads
Edited by HUBBA.HUBBA, 07 October 2018 - 03:46 PM.
#530 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 08 October 2018 - 06:42 PM
Sorted the gasket and now it sounds like I have a load of sparrows in the super charger.
A phone call to stuart and transpires it's a leak on the inlet manifold. Needed some blue stuff on both sides of the exhaust manifold gasket on just the inlet ports.Attached File  20181008_162223_resized.jpg   39.57K   3 downloads
Done.
Attached File  20181008_172534_resized.jpg   89.66K   4 downloads
Getting a price for a full roll cage, so a bit of calculating on the new corner sizes required.
Attached File  20181008_152949_resized.jpg   40.18K   2 downloadsAttached File  20181008_153009_resized.jpg   49.46K   1 downloads
Going to be back to its original height and it will miss my head.
Attached File  20181008_153211_resized.jpg   28.47K   1 downloads
Edited by HUBBA.HUBBA, 08 October 2018 - 06:50 PM.
#531 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 October 2018 - 05:53 PM
Got an email from Phil at BMS engineering saying my custom roll cage tubes are ready to pick up. So rude not to get down there asap.Attached File  20181023_163423_resized.jpg   51.27K   0 downloads
They do alot of secret work at BMS and when I walked in there, I was greeted by a prototype Aston Martin shooting brake. It looked superb. Wasn't allowed to take pictures though (for obvious reasons)
Attached File  DfAT3B-XkAAC62Q-1440x800.jpg   25.92K   2 downloads
Edited by HUBBA.HUBBA, 23 October 2018 - 07:30 PM.
#532 nicklouse
  • 18,565 posts
Posted 23 October 2018 - 10:40 PM
Attached File  C53C490D-AC09-4EE7-8643-EEE758B2428C.jpeg   87.87K   11 downloads
Look what I have just seen.
#533 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 24 October 2018 - 10:57 AM
I like that. An Axe that's what I need! I've got some little storage boxes to put on the the front wing too. Single spot light looks good.
B T W -  I have decided to go down the hydraulic suspension route so I can raise it up at the flick of a switch. So watch this space!
Edited by HUBBA.HUBBA, 24 October 2018 - 11:00 AM.
#534 nicklouse
  • 18,565 posts
Posted 24 October 2018 - 11:01 AM
seen how the ariel  (sp) goes back to the front in a big hoop.
#535 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 24 October 2018 - 11:43 AM
Is that a Camo 'bag-for-life' on the front?  >_<
#536 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 24 October 2018 - 01:45 PM
I did miss that. You and your 'ariels'.
#537 nicklouse
  • 18,565 posts
Posted 24 October 2018 - 01:50 PM
one of the problems with being dyslexic some words just don't work in my brain, aerial. you know it ain't right but can't work it out.
#538 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 October 2018 - 08:06 AM
wasn't on about the spelling ( didn't realise it was wrong) more about your ariel fixation.
#539 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 28 October 2018 - 07:42 PM
Started the new roll cage. I need to do this do I can get a roof on and put it out dide do I can work on my mini.Attached File  20181027_154051_resized.jpg   70.05K   0 downloadsAttached File  20181027_154059_resized.jpg   48.51K   1 downloads
Covered the seats with a welding/fire proof blanket. Excuse the welds, wanted to make sure I had good penetration.
Attached File  20181027_154233_resized.jpg   55.59K   1 downloads
Bit of a sketchy moment welding next to a vented fuel cap, so took the cap off, 2 layers of plastic and a shed load of duck duct tape.
Attached File  20181027_154111_resized.jpg   44.64K   2 downloads
New leather welding apron worked well.
Attached File  20181027_154203_resized.jpg   30.26K   0 downloads
Was going to chop off the mounting points off the old roll cage but have decided to put new ones on using more bolts. Also hopefully keep the old one more sellable. Waiting for the new laser cut plates to arrive before I can crack on.
Edited by HUBBA.HUBBA, 28 October 2018 - 07:49 PM.
#540 nicklouse
  • 18,565 posts
Posted 28 October 2018 - 08:14 PM
re the fuel cap i would have left it on and made sure there was a metal sheet over it. hot rocks will go through just about anything.
