My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#511 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 15 September 2018 - 04:14 PM
I minor technicality you shouldn't care about:
The buckle on the strap's the wrong way round, the cutout goes with the free end so you can pinch the webbing through it as a quick release.
Might save your life if you ever have to dig your way through a snow drift in blizzard conditions and the strap's frozen  :P (Fair do's, that scenario doesn't go with the colour scheme).
It wouldn't go that way. The strap is folded under and stitched and I have left the fold on the inside. If that makes sense.
#512 Risky
Risky
  • 213 posts
Posted 15 September 2018 - 05:22 PM
Nice build. I like the desert/military look on it!
#513 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 28 September 2018 - 09:12 PM
Had an expansion tank made up by concept racing. Needed a bit of trimming down on the brackets. Pleased with the fit. Attached File  20180927_184628_resized.jpg   39.13K   1 downloadsAttached File  20180927_184658_resized.jpg   45.09K   2 downloadsAttached File  20180927_185350_resized.jpg   20.82K   1 downloadsAttached File  20180927_200504_resized.jpg   61.6K   3 downloads
Edited by HUBBA.HUBBA, 28 September 2018 - 09:49 PM.
#514 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 28 September 2018 - 09:23 PM
Unfortunately after a couple of laps round the block. I noticed a noise under load I wasn't used to hearing. Looks like the sodding head gasket has gone. Noticed mayo on the oil cap the other day. After wiping clean it came back after 1 mile. Looks like oil has sprayed out the side of cylinder 4 end. Gasket ordered in readiness prior to having a look.Attached File  20180928_150817_resized.jpg   66.73K   2 downloadsAttached File  20180928_150827_resized.jpg   65.59K   0 downloadsAttached File  20180928_150847_resized.jpg   63.65K   0 downloadsAttached File  20180928_150903_resized.jpg   49.98K   0 downloads
I wouldn't mind so much but I have only done 50 miles in it
Edited by HUBBA.HUBBA, 28 September 2018 - 09:43 PM.
#515 nicklouse
  • 19,063 posts
Posted 28 September 2018 - 09:59 PM
mayo on the cap means little. what does it look like on the dipstick?
colder weather more water vapour to make mayo.
#516 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 September 2018 - 06:54 AM
I'll check the dip stick later. The mayo was there when the weather was hot too. Also I think the pressure is high in the coolant. Wasn't too hot but it wet itself. I tried to show in the pictures but oil had sprayed out the side (looks like its come from gasket)over my breather pipes.
#517 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 September 2018 - 07:59 AM
Checked dip stick and it's fine. Nice clean, clear oil. Suppose it could be the rocker cover. Stuart G warned me the silicone ones are crap. I'll whack a cork one on and see
#518 nicklouse
  • 19,063 posts
Posted 29 September 2018 - 09:48 AM
pressure can not be too high in the coolant you have a pressure cap on the system that reduces the pressure if it gets too high.
nothing wrong with the silicon ones they just take a bit to make sure they are seated correctly and you don“t over tighten them as they will just spread out of the way. really should be a harder mix.
and mayo in the cap is just any water that has condensed in the engine being evaporated out. happens as the weather gets colder and when cars have hardly been used. more visible with open breathers as it does not get sucked out and burnt.
#519 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 September 2018 - 10:02 AM
Upon further inspection unfortunately it is the gasket. Water leaking out the side. Never seen that before.
#520 MrBounce
MrBounce
  • 2,686 posts
Posted 29 September 2018 - 12:53 PM
I've seen it before. I changed a head gasket on a 998 back in the 90s and used a rubbish cheap gasket. When we fired it up it started leaking water straight away. Replaced it with a Payen gasket and had no further issues. It could be a gasket sealing issue rather than something worse.
#521 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 29 September 2018 - 01:21 PM
it was a bk450 and a bk450 has been ordered
#522 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,740 posts
  • Name: Chris
  • Local Club: None
Posted 29 September 2018 - 03:23 PM
I thought vines HG had gone when it hadn't, it turned out i had burnt out an exhaust valve. Still not sure why it was leaking between head and block
#523 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 30 September 2018 - 03:15 PM
Head off. Despite the Surfaces bring sh#tted up underneath they are fine, no putting. Surprised how black The surfaces are though. The rings on the gasket are intact. Some the composite had broken away and there's a crease underneath. Judt waiting on the new gasket to arrive now. I wonder what the situation with guarantees for gaskets. Surely it shouldn't fail like that?
Attached File  20180930_143050_resized.jpg   26.94K   2 downloadsAttached File  20180930_143058_resized.jpg   43.62K   4 downloadsAttached File  20180930_131729_resized.jpg   48.67K   2 downloadsAttached File  20180930_131926_resized.jpg   58.12K   2 downloadsAttached File  20180930_131739_resized.jpg   77.09K   2 downloadsAttached File  20180930_131931_resized.jpg   66.18K   3 downloads
#524 MrBounce
MrBounce
  • 2,686 posts
Posted 30 September 2018 - 04:03 PM
That looks like it may have been a packaging issue, and by that I mean that something heavy may have been placed on top of it at some point at a funny angle, causing what looks like some sort of crush damage. Easy to miss something like that.
You will never get any guarantees with gaskets from the manufacturer unless it's unused. Too many variables otherwise.
#525 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 06 October 2018 - 04:23 PM
FFS! Spent this afternoon putting the new hg in. Torque every thing up. Fill with water. Haven't even started it up and it's leaking water out of the same spot. I'm loosing the will to live.Attached File  20181006_170416_resized(1).jpg   43.92K   1 downloadsAttached File  20181006_170408_resized(1).jpg   73.49K   0 downloads
Edited by HUBBA.HUBBA, 06 October 2018 - 04:24 PM.
