My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#451 GraemeC
GraemeC
  • 7,437 posts
Posted 26 August 2018 - 07:29 PM
That nut looks like it’s had lots of hold - it wouldn’t matter if the line was right on the edge, as long as you have a good wide band like you do. If it was only a thin line that had worn off I’d be more worried.
#452 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 26 August 2018 - 09:09 PM
http://m.minispares....~shop/NAM9075MS
Would these do?
My brother had the same as you and eventually pulled thru his rim, his rims where alloy tho.
Ben
It's hard to see without comparing the 2
wrong seat.
what wheel brand?
John Brown wheels
#453 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 26 August 2018 - 09:16 PM
The contact area is about half of the non painted bit. Here's another picture you can just about see a groove on the inside where the wheel hole stops.
Attached File  20180826_220356_resized.jpg   27.6K   0 downloads
I have markered it black to show the area that is not mating (between the the wheel hole and the stud). It also shows the groove a bit better.Attached File  20180826_220547_resized.jpg   27.76K   0 downloads
#454 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 26 August 2018 - 09:19 PM
i think you have the wide seat ones already
http://www.minispare...MS.aspx|Back to
 you may need to look at some non mini ones IE: not 11/16 socket fitting but the same thread.
do you know what thread the studs are?
#455 GraemeC
GraemeC
  • 7,437 posts
Posted 26 August 2018 - 09:25 PM
That doesn’t look ideal. Are the wheels new, if so and they are sold as Mini fitment they really shouldn’t have such a large stud hole.
The studs are 3/8” UNF thread.
Edited by GraemeC, 27 August 2018 - 06:33 AM.
#456 nicklouse
  • 18,564 posts
Posted 26 August 2018 - 09:44 PM
what is the size of the the holes in the wheel?
#457 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 August 2018 - 07:36 AM
Bought them at himley hall from the jbw stall
#458 GraemeC
GraemeC
  • 7,437 posts
Posted 27 August 2018 - 08:33 AM
If they sold you the wide seat nuts to go with them, then I’d assume they’re aware they’re ‘not quite right’.
I think you’ll struggle to find bigger seated nuts with the 3/8 thread. And, even if the seat was bigger, they’d only have the same hold.
As long as you don’t overtorque them and keep an eye on them I don’t think you’ll have an issue. There’s still a lot of meat before the bore of the hole is anywhere near the outer diameter of the nut seat.
The only thing I would check is that the tip of the nut doesn’t protrude through the wheel such that it tightens onto the drive flange before actually clamping the wheel properly- if it does the wheel hole will wear larger in no time. This is unlikely with the dome seat nuts though.
Edited by GraemeC, 27 August 2018 - 08:33 AM.
#459 Ethel
  • 25,915 posts
Posted 27 August 2018 - 11:37 AM
Google 3/8-24 lugnuts, bound to be more options across the pond.
Your spare's a factory steelie, how does it compare? You could also press in some Plasticine to get a better idea of the seat angles.
#460 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 August 2018 - 04:31 PM
Haven't had chance to measure but here's a picture.
Attached File  20180827_165224_resized.jpg   33.04K   2 downloadsAttached File  20180827_165321_resized.jpg   23.69K   1 downloads
Edited by HUBBA.HUBBA, 27 August 2018 - 04:32 PM.
#461 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 August 2018 - 04:33 PM
Any guesses what I have started making today
Attached File  20180827_144713_resized.jpg   83.81K   0 downloads
#462 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 August 2018 - 04:35 PM
Sprayed up sump guard.Attached File  20180827_144733_resized.jpg   52.64K   3 downloadsAttached File  20180827_155505_resized.jpg   55.37K   2 downloads
#463 nicklouse
  • 18,564 posts
Posted 27 August 2018 - 05:26 PM
attachicon.gif 20180827_165224_resized.jpgattachicon.gif 20180827_165321_resized.jpg
those are BIG almost as if they are for a different wheel stud size. may be 7/16" UNF bolts/nuts.
#464 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 27 August 2018 - 09:03 PM
How about these? Might just buy one and compare before I buy a load.
https://www.ebay.co....redirect=mobile
#465 nicklouse
  • 18,564 posts
Posted 27 August 2018 - 09:31 PM
look like a taper seat yours should be a radii (use bluetac to get a profile) and i think they would bottom out before clamping the wheel.
