My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#391 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 02 August 2018 - 03:51 PM
Well looks like the tacho isn't compatible with electronic ignition, must be off a lotus or MG. I'm sure if I resell if on eBay the new owner will love a sand coloured bezel?. Think I'll respray it matt black. So off to minispares to donate £140 it is then.
Attached File  20180802_163718_resized.jpg   55.55K   0 downloads
Edited by HUBBA.HUBBA, 02 August 2018 - 03:53 PM.
#392 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 02 August 2018 - 06:18 PM
Surely it's cheaper to get it converted then you don't need to shed out silly money and you can keep the bezel colour
#393 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 02 August 2018 - 06:25 PM
Doesn't Spyida do a conversion module?
#394 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 03 August 2018 - 07:39 AM
It's time really. Say if costs £70 -80 overall for the conversion, the gauge will have nearly cost as much as a new one with a warranty. Any money saved, off set against my time, it's just not worth it. Plus I don't want to wait x amount of time for the conversion to be done.
#395 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 03 August 2018 - 07:54 AM
Finally got the engine bay wiring done. The tacho wiring was really hanging over me for some reason. So to be honest it's quite a relief to be getting a new one instead.Attached File  20180802_195859_resized.jpg   80.44K   2 downloadsAttached File  20180802_195916_resized.jpg   50.79K   2 downloads
#396 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 03 August 2018 - 08:08 AM
Got back onto the dash wiring now. The starter button was the first thing. Had some spare white and red wire left over So, cut the white ingnition wire and the white/red starter. Ran 2 lengths of wire from the cut wires to where the starter button is on the dash. Spurred the one white/red off the white, crimped and heat shrink. Attached the other new white/red wire to the one cut, crimped and heat shrink. For the crimping I tend to use the yellow or blue insulated connectors and cut off insulation. Don"t know where to but non-insulated crimp connectors. Terminated the starter wire off the barrel. Then couple of spades at the switch end.Attached File  20180802_202706_resized.jpg   48.28K   0 downloadsAttached File  20180802_203022_resized.jpg   43.56K   1 downloadsAttached File  20180802_202812_resized.jpg   41.73K   1 downloadsAttached File  20180802_203526_resized.jpg   32.93K   1 downloadsAttached File  20180802_203642_resized.jpg   76.09K   0 downloadsAttached File  20180802_204429_resized.jpg   21.37K   0 downloadsAttached File  20180802_204608_resized.jpg   31.52K   0 downloadsAttached File  20180802_205158_resized.jpg   39.06K   0 downloadsAttached File  20180802_205208_resized.jpg   58.03K   0 downloads
#397 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 August 2018 - 09:24 PM
Feeling fed up today. Got the wiring done. Fuel in. There were a few gremlins that got sorted. But turning the engine over to get oil pressure up I am getting no pressure showing!! Tested gauge and whilst it transpires it's not the most accurate (shows 50 psi at 70). It still moves when attached to pressurised air. I had fitted a ball and spring pressure relief and took great care fitting the turbo oil pump- making sure it was all clean, oiled the gasket and tightened up correctly. So a bit flummoxed at the moment. How may spins of the starter should it take to get pressure on a freshly built engine?
Edited by HUBBA.HUBBA, 11 August 2018 - 09:26 PM.
#398 nicklouse
  • 18,564 posts
Posted 11 August 2018 - 09:37 PM
it can take a few. dont forget no plugs in and fuel and ignition off.
check each part of the line flows. do you have any parts in the routing that is not just the pipe and the block connector and gauge?
#399 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 August 2018 - 07:44 AM
Did leave plugs in. Will try again without. Fuel and ignition was off. I did fill the pump with oil when building but not sure how long that would last in there. It's justca new goodridge hose from the 'T' adapter for the oil light and that's it.
When you say, "check each part of the line flows". Like what? Take oil filter off see if oil pumps out and fill it if necessary . Did notice a bit of oil on the ball end of the spring in the oil relief valve.
Edited by HUBBA.HUBBA, 12 August 2018 - 07:45 AM.
#400 Ethel
  • 25,915 posts
Posted 12 August 2018 - 09:32 AM
It can take an age. Some fill the pump with grease  instead of oil so it won't drain down. You can also try priming the pump  via the transfer pipe hole, turn the engine backwards to pull the oil in. Also fill the filter if you haven't already.
#401 nicklouse
  • 18,564 posts
Posted 12 August 2018 - 11:22 AM
nope, the line to the gauge if there is anything blocking it you may have pressure but no reading another check is looking for oil at the rockers.
plugs out then the engine will spin faster and just squirt some oil through the banjo bolt fitting onto the pump.
#402 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 August 2018 - 11:27 AM
Still no joy. Plug a out. There was no oil at all in filter! Filled it. Wasn't sure if taking the relief valve out would enable oil to come out there, but it didn't. So how do you back fill the pump using the transfer pipe hole, as in what do you attach to the hole to get the oil in? Also turning the engine backwards, Jack up one side in top gear and rotate the wheel back?
#403 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 August 2018 - 11:32 AM
No banjo, do you mean here.
Attached File  20180812_122931_resized.jpg   85.44K   0 downloads
#404 nicklouse
  • 18,564 posts
Posted 12 August 2018 - 11:39 AM
yep. and an oil can
#405 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 August 2018 - 12:10 PM
And on the 7th day god created Nick and Ethel. Thank you so much chaps I was starting to dred the worse. About 70 psi so on this gauge that's about 90-100.
Attached File  20180812_130146_resized.jpg   34.65K   2 downloads
Here's a picture of me back filling / priming the pump just in case anyone does a search for it and needs to see where.
Attached File  20180812_125052_resized(1).jpg   61.58K   1 downloads
