Bit of paint
Posted 15 July 2018 - 05:52 PM
Posted 15 July 2018 - 05:55 PM
Posted 15 July 2018 - 05:58 PM
Posted 15 July 2018 - 06:01 PM
Posted 18 July 2018 - 08:14 PM
Here's an overall prospective picture. Starting to feel like a car now.
saw these
seats.jpg 84.29K
5 downloads
Posted 18 July 2018 - 09:01 PM
wow! They look amazing. Too late nowsaw theseHere's an overall prospective picture. Starting to feel like a car now.
Posted 20 July 2018 - 08:54 AM
I've disliked every mock-military vehicle i've ever seen.... untill i saw this one .
A truly outstanding build: absolutely luv the thought & effort that has gone into improving/modifying so many parts in new & innovative ways .
Posted 20 July 2018 - 11:36 AM
That's praise indeed. Thank you. Nearly there now. Last night filled and bled the clutch. Got rid of brake fluid level wiring, finished off the breather pipework. Hopefully finish wiring and fluids in asap.I've disliked every mock-military vehicle i've ever seen.... untill i saw this one
A truly outstanding build: absolutely luv the thought & effort that has gone into improving/modifying so many parts in new & innovative ways.
Posted 23 July 2018 - 08:44 PM
Posted 23 July 2018 - 08:54 PM
WR tends to be the wire that gets things started.
where it goes depends on what is at the other end.
might help
http://www.theminifo...ttach_id=193847
Posted 23 July 2018 - 08:58 PM
Posted 24 July 2018 - 09:49 AM
Just seen your reply. Definitely looks like the auto inhibitor then. Cheers.WR tends to be the wire that gets things started.
might help
Posted 26 July 2018 - 10:46 AM
Posted 26 July 2018 - 11:01 AM
Had a break from wiring and did my rocker gaps. That highlighted a new issue, could not select 2nd or 4th gear. Hmmmm. As the gear box was rebuilt by Mr Guess I looked elsewhere. Remembering there were different lengths of gear rod brace bar and must have put a longer one on a shorter selector rod. An hour and half later. Swapped over the top rod, but I had to remount the gear lever housing 10mm closer to the engine. Now I need to some how tidy up where it bolts through the floor.
20180725_155442_resized.jpg 51.21K
1 downloads
20180725_155447_resized.jpg 54.27K
0 downloads
20180725_164802_resized.jpg 50.72K
3 downloads
Also finally tightened up the 3rd gear bias spring. I am supprised how it makes the feel of the gear lever. Makes it feel like a modern car. Hopefully soon see what it's like to drive with.
20180725_164750_resized.jpg 50.65K
3 downloads
Edited by HUBBA.HUBBA, 27 July 2018 - 08:49 AM.
Posted 26 July 2018 - 11:05 AM
mmm LCB clamps. them bolts are going to be a pain. I would rotate the clamps around as you don't want then catching on any rough stuff.
