My New Amc Moke Project -Desert Rat Sleeper
#301
Posted 11 June 2018 - 07:06 PM
#302
Posted 12 June 2018 - 06:03 AM
#303
Posted 12 June 2018 - 10:11 AM
#304
Posted 12 June 2018 - 12:16 PM
cause that is where it sits on the inner shaft. In the picture it shows the lowest point it can go on the inner shaft as the shaft goes wider. I've looked other threads, looks like I have an old type. The plastic bottom bush seems to be for newer ones.why do you want to get it past the notch?
#305
Posted 13 June 2018 - 10:53 AM
Does the wider part of the inner column not sit below the outer column once installed?
Edited by GraemeC, 13 June 2018 - 10:56 AM.
#306
Posted 13 June 2018 - 08:54 PM
I’ve never had a problem, hence the question. As far as I know the plastic bush is supposed to fit all columns.
Just to illustrate I have taken a pick to show how far down it goes.
#307
Posted 13 June 2018 - 08:59 PM
#308
Posted 13 June 2018 - 09:01 PM
The ring you have on there isn’t needed now - that’s to retain the felt bush.
#309
Posted 13 June 2018 - 09:17 PM
Perhaps I should rephrase it. This how far down it SHOULD go. The plastic bush needs to get past that indented ring.Looks right to me - the inner column protrudes from the outer further than what you have them aligned there. See the close up pic on MiniSpares link.
Anyway It's a moot point now. I have given the felt a soak in oil and reused it.
#310
Posted 14 June 2018 - 12:37 AM
the column outer that uses that plastic bush is shorter than the earlier ones that use the felt. also it has 2 rings while the older like yours only has one. i think the inner can be used in either outer but you need the correct Bush or felt for the outer.
#311
Posted 15 June 2018 - 04:31 PM
Anyone know where I can get headlights from without a side light hole?
#312
Posted 15 June 2018 - 04:58 PM
Most Mini suppliers - usually sold as clubman ones.
http://www.somerford...roducts_id=4893
Edited by GraemeC, 15 June 2018 - 05:04 PM.
#313
Posted 15 June 2018 - 05:44 PM
61 quid? I'll continue the hunt. did try clubman but not much was coming up
Edited by HUBBA.HUBBA, 15 June 2018 - 05:45 PM.
#314
Posted 15 June 2018 - 06:04 PM
They’re listed as ‘without pilot’
This may work?:
https://www.minispor...pilot-6816.html
Edited by GraemeC, 15 June 2018 - 06:09 PM.
#315
Posted 15 June 2018 - 06:07 PM
Found some at old skool minis. they are 20 mins from me and open tomorrow. cheers
