My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#271 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 31 May 2018 - 08:05 PM
Went sand colour in the end and a few more ducting holes to boot.
Attached File  20180531_194904.jpg   48.6K   2 downloads
#272 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 31 May 2018 - 08:13 PM
I have that same gauge, but only upto 1 bar. The needle sits perfectly central (zero) when the engine is off.
I need to modify mine too... winds me up every time I look at it that it says turbo when it’s supercharged!
#273 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 31 May 2018 - 08:14 PM
This is awesome!!
#274 nicklouse
  • 18,562 posts
Posted 31 May 2018 - 08:38 PM
I bought a boost gauge which I intend to customise (of course!). Just wondered if this looks right. It's a cheapo TIM one, surely the needle should be sitting on zero! I bought an old TIM gauge prior to this one to take apart and that one had the needle in the same place Too!!?? Anyone had any experience with these?
think on where is the air pressure Zero?
#275 KTS
KTS
  • 2,420 posts
Posted 31 May 2018 - 09:24 PM
i think zero on the scale would mean standard atmospheric pressure rather than absolute vacuum...
unless your garage is buried deep underground, i'd expect the guage to be reading zero - maybe once it's fitted and exercised a little it might settle to the correct resting position
#276 nicklouse
  • 18,562 posts
Posted 31 May 2018 - 09:29 PM
i would not, the lower you go the higher the pressure.  it is reading atmospheric pressure ish. when fitted it will show what the engine is making compared to atmospheric pressure.
#277 KTS
KTS
  • 2,420 posts
Posted 31 May 2018 - 10:05 PM
i'd expect the gauge to show 0 atm ('boost pressure') at normal atmospheric pressure.
the photo appears to show the gauge indicating about 0.4 atm - which i think would equate to approximately 6psi boost.  that's well outside the range of normal meteorological air pressure variations
#278 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 01 June 2018 - 07:34 AM
Think I'll test it with another gauge
#279 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 June 2018 - 10:00 AM
Unfortunately the test is a negative. Still the same.Attached File  20180602_105050.jpg   34.85K   2 downloadsAttached File  20180602_105116.jpg   37.71K   2 downloads
JJC race and rally say it may have moved whilst on the post and a bit of pressure would reset it. But it hasn't worked
Edited by HUBBA.HUBBA, 02 June 2018 - 07:40 PM.
#280 Ethel
  • 25,914 posts
Posted 02 June 2018 - 11:17 AM
It's always going to measure relative pressure. There's no sealed vacuum, just the atmosphere on one side and your inlet manifold on the other - it should always read zero if the engine's not pumping air.
Send it back if you can. If not, it does look to be reasonably accurate comparing the pressure increase recorded in your pics so you could pull it apart and refit the needle.
#281 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 June 2018 - 12:25 PM
I'm going to suggest to the seller for a bit of discount if I fix it.
#282 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 02 June 2018 - 12:28 PM
What am I making today?
Attached File  20180602_114148_resized.jpg   62.28K   2 downloads
#283 Ethel
  • 25,914 posts
Posted 02 June 2018 - 02:22 PM
... I suppose it's just possible something is obstructing the mechanical bits of the gauge. You could apply some vacuum to confirm it can do a full sweep - bearing in mind it would read high by the same amount if it is the fit of the needle.
#284 KTS
KTS
  • 2,420 posts
Posted 02 June 2018 - 04:13 PM
..a hypobaric chamber to house your boost gauge at -0.4atm so it reads true ?  ;D
#285 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 02 June 2018 - 05:54 PM
Hydroponics tent for “tomato’s” ?
Edited by minihobbymini, 02 June 2018 - 05:54 PM.
