My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#211 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 24 October 2017 - 05:46 PM
One thing I have noticed is there is play with the big ends even though it is torqued down. Which is a bit concerning or is there movement when it all is cold?
So should I expect any lateral movement?
#212 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 27 October 2017 - 10:06 AM
How much have you got?
#213 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 November 2017 - 05:34 PM
Well got round to doing a bit more today. Plastigauged the bearings and all is good.
Attached File  20171105_144454.jpg   39.47K   0 downloads.
So time to get the head on.
Firstly the bolts - ARP of course
Attached File  20171105_151451.jpg   59.49K   1 downloads
Clean up the threads as per ARP instructions and a blast of air to get any more bits out.
Attached File  20171105_152243.jpg   45.09K   3 downloadsAttached File  20171105_152716.jpg   45.62K   1 downloads
Thought I'd measure the stroke whilst I was at it so I could work out the compression ratio later.
Studs in and BK450 on. Head on.
Ready for rockers. Will have to get cam and oil pump in first.
I had a few more pics to put one but they were over 2mb. (Stupid up loader!)
Attached File  IMG_20171105_1737003_rewind.jpg   68.68K   0 downloads
Attached File  IMG_20171105_1737405_rewind.jpg   56.22K   0 downloads
Attached File  IMG_20171105_1737288_rewind.jpg   54.4K   0 downloads
Edited by HUBBA.HUBBA, 05 November 2017 - 05:46 PM.
#214 nicklouse
  • 18,559 posts
Posted 05 November 2017 - 05:42 PM
mmmm i would get a bottom tap. (or a plug would be better that your taper) so you do actually clean the threads the whole way down.
#215 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 05 November 2017 - 05:49 PM
Did it as far as it would go. Think it went deeper than the threads on the studs. After the blast of air I did it again and nothing more came out.
Edited by HUBBA.HUBBA, 05 November 2017 - 05:53 PM.
#216 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 06 November 2017 - 09:02 PM
Need a timing cover without breather. Please let me know if anyone has a decent one. Cheers.
Attached File  CAM4904-USED-classic-mini-a-plus-timing-chain-cover-no-breather-seven-mini-parts-www.7ent.com (1).jpg   59.68K   0 downloads
#217 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 07 November 2017 - 09:02 PM
Aagggh! Just realised as I have used an SPI head, that it doesn't have a hole for the water temp sender. Anyone know what thread they are, as I'll need to tap a hole.
#218 Midas Mk1
Midas Mk1
  • 5,773 posts
  • Local Club: S.U.N.M.C
Posted 07 November 2017 - 09:13 PM
Temp sender in thermostat housing, easy fix :)
#219 Midas Mk1
Midas Mk1
  • 5,773 posts
Posted 07 November 2017 - 09:14 PM
Or in the bypass hose take off on the head and use and spi sandwich plate if your running a heater :)
#220 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 November 2017 - 07:41 PM
The timing cover arrived today. Should have taken a before pic. Gave it a blast in the cabinet and its come up really well ( until I ran out of media).
Can anyone tell if the crank seal is replaceable. Doesn't seem to want to come off and don't want to force it.
Attached File  20171110_172220.jpg   36.81K   2 downloadsAttached File  20171110_172239.jpg   41.59K   1 downloads
#221 jonlad
jonlad
  • 325 posts
Posted 10 November 2017 - 08:28 PM
They come out with a bit of a tap, i used a big socket that was just smaller that the hole in the metal cover... and of course a BFH
Is it worth chancing it for the for the cost of a new one? :unsure:
Great thread by the way, i enjoy your updates
Edited by jonlad, 10 November 2017 - 08:29 PM.
#222 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 10 November 2017 - 10:17 PM
Cheers dude
#223 Ethel
  • 25,910 posts
Posted 11 November 2017 - 12:23 PM
Temp sensor is 5/8unf.
#224 panky
panky
  • 1,789 posts
Posted 11 November 2017 - 01:15 PM
There's an excellent resource on the MMOC forum for thread sizes. Obviously for Morris Minors but the engine section should be the same for most Minis. It does state that the temp sender thread is 5/8 UNF
http://www.mmoc.org....php?f=4&t=51709
Scroll down a bit for the table.
Edited by panky, 11 November 2017 - 01:16 PM.
#225 Drake
Drake
    Just On Tickover
  • 9 posts
Posted 11 November 2017 - 05:26 PM
enjoyed reading that from start to end - making a great job and look forward to the updates.
I have a 1986 AMC Cub that I restored a few years back, my fuel tank was same as yours inside (corrosion) but given mine is 31 year old I expected it !! Also my sender was mounted on the side not the top and is from a Van..
Charles Anderson obviously did a few updates to the chassis as quite a few differances to mine, if you have not sorted your handbrake out I can share how mine is, the exhaust on mine is standard Mini but I had to put an extention piece in due to the wheel base (about 4" from memory)
Anyways - i'll keep an eye on this...
