Sounds like some of the end caps or con rod ends are distorted
My New Amc Moke Project -Desert Rat Sleeper
#181
Posted 22 October 2017 - 12:25 PM
#182
Posted 22 October 2017 - 01:07 PM
What could cause that?
#183
Posted 22 October 2017 - 01:35 PM
They could have been over-torqued in the past and 'squashed' them or the engine over revved excessively and elongated them. The other possibility is that the caps and rods are miss-matched so the bores don't quite line up. Is there any sign of a step between cap and rod when they are put together?
#184
Posted 22 October 2017 - 02:03 PM
#185
Posted 22 October 2017 - 02:14 PM
#186
Posted 22 October 2017 - 02:18 PM
#187
They didn't need to mill the big end part of the crank just the mains. They supplied the bearings for me. 2 of them are fine.Are they the right size for the crank milling? Did the company that did the engine work give you a crib sheet of what bearing sizes to use?
#188
Posted 22 October 2017 - 02:26 PM
#189
Posted 22 October 2017 - 02:29 PM
Edited by HUBBA.HUBBA, 22 October 2017 - 02:30 PM.
#190
Posted 22 October 2017 - 02:38 PM
i would be getting them measured.
#191
Posted 22 October 2017 - 03:03 PM
#192
Posted 22 October 2017 - 03:16 PM
Have you tried swapping over the caps on the two rods that are tight.
#193
Posted 22 October 2017 - 03:19 PM
If youre not 100% sure what youre doing, get an engine builder to do it.
Thanks for that, but I'm not one for giving in. I know this is just my second engine rebuild, but I just didn't come across these issues the first time round. I'm not going to learn anything passing it to someone else to do.
I'll go and pop over to the machine shop in the week so they can measure it. In the mean time I might just try the good ones further up the crank and see what they are like.
#194
Posted 22 October 2017 - 03:22 PM
No, only because the machining marks match up. I'll try it and see. Even wondered about just turning the caps round so the tabs aren't on the same side
#195
Posted 23 October 2017 - 07:37 PM
Phew
