My New Amc Moke Project -Desert Rat Sleeper
935 replies to this topic
#166 timmy850
timmy850
  • 3,303 posts
  • Local Club: MITG
Posted 23 August 2017 - 03:17 AM
I think the manual specifies .003" end float, but from what I've been told you need a little bit more, like .004 to .006".
E.g.
http://www.theminifo...rank-end-float/
http://www.theminifo...at-measurement/
#167 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 23 August 2017 - 12:49 PM
I try to get mine to 004
#168 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 23 August 2017 - 08:05 PM
I'm sure I didn't have mess about like this last time I built an engine. I've asked the question in the tech section. So hopefully I'll get there.
On a more positive note I had a deliver from the US today, which was a lot quicker than I thought. Will have to definitely get rid of the old seats asap.
Attached File  20170823_203710.jpg   54.09K   1 downloads
Edited by HUBBA.HUBBA, 23 August 2017 - 08:06 PM.
#169 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 August 2017 - 08:08 PM
How do you get to 004 ? Buy a different thickness, sand them down or what?
#170 panky
panky
  • 1,789 posts
Posted 23 August 2017 - 08:57 PM
I ended up using the old thrusts on one side and a new over sized set on the other as two new ones wouldn't go in. Still had to take a couple of thou off by rubbing the back of the thrust on emery placed on a flat surface - you tend to loose the skin off your finger tips too :shy:  I measured the thickness first,  decided how much to take off and rubbed them down, measuring with a micrometer regularly so the thickness was reduced evenly across the area of the thrusts.
#171 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 August 2017 - 09:10 PM
That's what I've been doing. Guess I'll have to do it a bit more.:-)
#172 panky
panky
  • 1,789 posts
Posted 23 August 2017 - 09:17 PM
Takes a while - and a few sets of finger tips ;D
#173 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 24 August 2017 - 08:34 AM
^^^ this
I placed fine emery on glass to make sure it was flat.
#174 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 August 2017 - 04:41 PM
Thought I'd do something less stressful than engine building today so started the dash.Attached File  20170825_151655.jpg   48.34K   0 downloadsAttached File  20170825_151710.jpg   55.26K   1 downloads
Couldn't resist peeling off the protective coating Attached File  20170825_152201.jpg   65.22K   2 downloadsAttached File  20170825_152217.jpg   63.85K   3 downloads
Probably should have waited being I've got to cut a load of holes in it for the dials!
#175 panky
panky
  • 1,789 posts
Posted 25 August 2017 - 04:58 PM
You'll end up painting it matte black anyway, because of the reflection of you're grin when you drive it :D
Fosters, that reminds me I need a beer :highfive:
#176 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 August 2017 - 05:54 PM
I will be painting it but it won't be black. I'll give you a clue, it rhymes with 'and' and starts with 's'
#177 panky
panky
  • 1,789 posts
Posted 25 August 2017 - 06:02 PM
Strombolisiband- never heard of it
#178 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 25 August 2017 - 06:15 PM
I've just realised why you said fosters! Doh!
#179 panky
panky
  • 1,789 posts
Posted 25 August 2017 - 06:20 PM
And the compartment where the wiper motor is looks like an ideal place for a pack. Now where can we put the wiper motor
#180 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 22 October 2017 - 12:05 PM
Finally started to carry on with the engine build and its really getting on my nerves! Eventually sorted the main bearings and thrusts. But the big ends are playing up.
With 2 of my conrods, when I torque the nuts they are rock solid on the crank! And yes they are the right way round and clean. Tried the bearings on one of the other conrods on the same part of the crank and they were fine. So I'm at a bit of a loss.
Even tried it without the piston in the bore just in case the rings were a bit tight.
I don't understand what on the conrod could be causing it. I have no previous knowledge on the history of the engine, if it was running ok or not.
