1275 And Gearbox Weight?
5 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 05 January 2017 - 08:13 PM
Want to get an engine stand and wonder what spec to get. Any suggestons appreciated
#2 Swift_General
Swift_General
  • 871 posts
Posted 05 January 2017 - 08:44 PM
Never weighed the unit but seem to remember (I think from Haynes) 150kg for engine and gearbox.
#3 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 05 January 2017 - 09:25 PM
more than they look...
#4 CityEPete
CityEPete
  • 3,920 posts
Posted 05 January 2017 - 09:41 PM
The technical term is "shitloads", I remember the weight after throwing some complete running 1275cc engines in a skip 11 years ago, whoops!
#5 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 06 January 2017 - 05:02 AM
Weights
Car/engine (in kg)
Engine and transmission 850/1000
151
Traveller/Countryman
660
Engine and transmission 1275
154
Cooper 997/998 (dry suspension)
635
Engine alone
125
Cooper 997/998 (hydrolastic)
650
Mini Automatic Mk1
630.8
Cooper S (dry suspension)
~640
850/1000 MkII
654
Cooper S (hydrolastic)
~634.5
Clubman Auto
658
Van
605
Clubman Manual
638
Pickup
604
Clubman Estate
686
Moke
562
1275GT
707
Parts (also in kg)
bare block casting 998
30
gearbox (A) + diff + gears
26
head CAM 4810 + rockers, valves
15.5
crank 998
10
starter motor
4
alternator
4
bare HS2 carb
0.9
rod + piston 998
1
clutch (flywheel + plate + backplate 998)
11
radiator 998
3
air filter box + filter
1
transfer gear housing
3
clutch cover
2
manifold (cast iron, for HS2 998)
4
waterpump + pulley
1
plastic 11 blade fan
0.25
coil
0.8
battery
9
mechanical fuel pump
0.6
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 06 January 2017 - 10:13 PM
Weights
Car/engine (in kg)
151
660
154
635
Engine alone
125
650
Mini Automatic Mk1
630.8
~640
850/1000 MkII
654
~634.5
Clubman Auto
658
Van
605
Clubman Manual
638
Pickup
604
Clubman Estate
686
Moke
562
1275GT
707
Parts (also in kg)
30
26
15.5
crank 998
10
starter motor
4
alternator
4
bare HS2 carb
0.9
rod + piston 998
1
11
radiator 998
3
1
3
clutch cover
2
4
waterpump + pulley
1
0.25
coil
0.8
battery
9
0.6
So a 250 kg stand should be ok then?
