Positive Or Negative Earth
15 replies to this topic
#1 Gcal
Gcal
  • 128 posts
Posted 03 January 2017 - 12:58 PM
OK folks I'm new to the forum and need a bit of help. I have a 1978 mini 850 and unsure whether it is positive or negative earth, Haynes have it listed from 1969 onwards as negative earth if anyone has a mini of a similar age that could help.
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 03 January 2017 - 01:13 PM
It should be negative earth, presuming you have a battery fitted the shorter connector, usually black coloured, is nearest the boot lid and connects to the terminal marked "-" on the battery, your battery clamp may also be marked "-". The battery cable further in that disappears through the boot floor may be coloured red, have a "+" mark on the battery clamp or a red plastic cover. Of course it all depends on whether anyone has changed cables or clamps and not done them correctly.
#3 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 03 January 2017 - 01:50 PM
Should be negative earth at that year.
#4 Gcal
Gcal
  • 128 posts
Posted 03 January 2017 - 01:59 PM
I thought it was negative earth, would it cause any damage if the battery was connected wrong?
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 03 January 2017 - 02:04 PM
Possibly.
There are all sorts of diodes in the alternator that probably wont like it
#6 billy big skid
billy big skid
  • 47 posts
Posted 03 January 2017 - 02:26 PM
A bang, many sparks and a large lump on the back of your head from when you leapt backwards and rattled it on the parcel shelf.
#7 CityEPete
CityEPete
  • 3,920 posts
Posted 03 January 2017 - 06:01 PM
Getting the magic smoke back in can take ages!
#8 panky
panky
  • 1,791 posts
Posted 03 January 2017 - 06:09 PM
If you've got a stereo fitted then it's probably fried :ohno:
#9 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 04 January 2017 - 12:23 AM
Converting to negative earth is fairly simple - how-to guides can be found on the net.
Where are the connections on the coil hooked up to? You'll have to swap these over when converting (and other bits too)...
#10 Gcal
Gcal
  • 128 posts
Posted 04 January 2017 - 03:17 PM
Negative on coil to dizzy and positive on coil to solenoid
#11 tiger99
tiger99
  • 8,584 posts
Posted 06 January 2017 - 08:52 PM
If you have an alternator and have reversed the battery, the alternator will be ruined. It is unlikely to work at all, but if it does it will be for a very short and unpredictable time. The diodes and windings will have been grossly overheated.
#12 Gcal
Gcal
  • 128 posts
Posted 31 January 2017 - 06:53 PM
Been out and checked connections and it turns out that it is positive earth after all with an alternator,if I swap the battery terminals the ignition light stays on,how easy is it to convert it?
#13 Swift_General
Swift_General
  • 871 posts
Posted 31 January 2017 - 08:12 PM
What makes you think it's positive earth? Not sure when the changeover was (I'm thinking possibly '69 with the Mk3?) but certainly long before '78. Also never heard of a positive earth alternator.
#14 Carlos W
Carlos W
  • 10,114 posts
Posted 31 January 2017 - 08:14 PM
Please don't swap the battery connections around
#15 Gcal
Gcal
  • 128 posts
Posted 31 January 2017 - 08:49 PM
Red positive terminal cover on earth wire and battery cable has smaller connection and earth has the larger battery terminal
